BobTRF's avatar
BobTRF
Orbi Pro SRR60 wired pps?
What is the SRR60's packets per second forwarding capacity between its LAN and WAN ports, specifically small packets (RTMP uses 128 bytes)?
  • Speaking to engineering about this and based on testing the results were a packet size of 128bytes had a throughput of 100mbps and a packet size of 1460bytes had a throughput of 940mbps. Results may varie depending on current network traffic and cabling.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    BobTRF,
    Welcome to the community! :)
    I have already inquired your concern to the higher tier of NETGEAR Support.  I will post here once I got a feedback.
    DaneA
    NETGEAR Community Team
  • MrJoshW's avatar
    MrJoshW
    • BobTRF's avatar
      BobTRF
      Thank you MrJoshW for that throughput number, for both small and large packets.
      If my math is right, does that mean we should expect it to handle about 97K small TCP packets per second?
ProSupport for Business
