nhinkle
Aug 31, 2018Apprentice
Orbi pro in access point mode dropping RDP connections
I have just installed an Orbi Pro system in my house. It is configured in access point mode with a Nighthawk R7000 acting as the gateway to the internet. The wifi on the r7000 is turned off. I am u...
- Sep 06, 2018
So, I opened a support case. I was put on hold while being transfered to Orbi pro support.
After 40 minutes on hold, I started a chat with Amazon support. Chat was online in less than a minute. In about 5 questions the Amazon rep determined the product was defective. In another 2 I had an RMA and UPS pick up to return the product for full refund. At that point, the Orbi pro support answered the line - barely intelligible Indian accent. After ten questions he wants to remote into my network - that security breach isn't happening.
Solution to Orbi Pro problem = return for refund.
DaneA
Sep 05, 2018NETGEAR Employee Retired
I got a feedback from the higher tier of NETGEAR Support just a while ago. As per the higher tier of NETGEAR Support, the engineering team tried to replicate your issue but so far have not seen the same issue as yours.
Kindly answer the questions below:
a. What tool did you use to remote control VM/RDP server?
b. How many clients (wired & wireless) in this environment? Kindly enumerate also the OS or iOS version or Android version of the devices. For example: 2 iPhone X with iOS 11.4.1 and 2 PCs wired running Windows 7 Ultimate
c. Kindly provide floor plan. The main purpose of this is to setup similar topology as yours to replicate your concern. Kindly post images or screenshots.
d. What is the speed test result of your laptop/PC when the issue happens? Kindly post screenshots of this.
DaneA
NETGEAR Community Team
nhinkle
Sep 05, 2018Apprentice
Hi DaneA
The deterioration of the capabilities of the Orbi Pro has gone way beyond just HyperV and remote desktop protocol (RDP). Now my samsung galaxy s6 (Android 7) is reporting authentication errors and all our devices are dropping connections - 2 roku, Samsung S2 tablet (android 7), Dell windows 10 PC, HP Windows 10 PC. The wifi is just completely unreliable.
Ping -t shows request timeouts frequently, for example:
C:\Users\nhinkle>ping 192.168.1.102 -t
Pinging 192.168.1.102 with 32 bytes of data
Reply from 192.168.1.102: bytes=32 time=1ms TTL=128
Reply from 192.168.1.102: bytes=32 time=3ms TTL=128
Request timed out.
Request timed out.
Reply from 192.168.1.102: bytes=32 time=2ms TTL=128
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.102:
Packets: Sent = 36, Received = 30, Lost = 6 (16% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 3ms, Average = 1ms
Control-C
^C
This is constant, whether I have the Satellite on or off. With the Satellite off, I still get this and the topology is: r7000 with wifi off and its' lan port one hard wired to the WAN port of the SRR60. 192.168.1.102 is a server on lan port 3 of the R7000. In this configuration, the Wifi on the SRR60 just drops packets constantly but if I use a lan port on the back of the SRR60, I get no packet loss. So I can have functional Wifi in my house, I have had to drop back to my original configuration where I was using an older R7000 as an access point. I now have that old R7000 in the exact same place as the SRR60 and I swapped the cable over and ran Ping -t to that R7000 for 30 minutes with 0 packet loss.
I don't see the point of doing a speed test as speed is not the issue. When the issue happens, there is no speed as the connection is dropped.
- nhinkleSep 06, 2018Apprentice
