Retired_Member
Mar 21, 2020SRR60 loses settings when power cycled
2020-03-21 08:29 PM SRR60 loses settings when power cycled 1-ongoing issues with dropped internet connection 2-ongoing issues with wifi dropping from devices 3-moving my router ...
- Retired_MemberMar 29, 2020
Problem Solved!
Orbi replaced with another brand system thats simple IT that just works.
Anyone want a base station and two satellites?
Best of luck all.
DaneA
Mar 22, 2020NETGEAR Employee Retired
Retired_Member,
Kindly try to update the firmware of your SRR60 to the latest version which is v2.5.1.106 then observe if the same problem occurs. You can download the firmware here.
DaneA
NETGEAR Community Team
Retired_Member
Mar 22, 2020is this recommended because it's a default response: "run latest firmware" or because this firmware has a specific solution to any or all of my issues? becuase I know it has another problem, which is why I backed up one.
also note: I went to latest firmware in effort to improve connectivity issues, but lost ability to see connected devices.
