Retired_Member
Mar 21, 2020SRR60 loses settings when power cycled
2020-03-21 08:29 PM SRR60 loses settings when power cycled 1-ongoing issues with dropped internet connection 2-ongoing issues with wifi dropping from devices 3-moving my router ...
- Retired_MemberMar 29, 2020
Problem Solved!
Orbi replaced with another brand system thats simple IT that just works.
Anyone want a base station and two satellites?
Best of luck all.
RaghuHR
Mar 23, 2020NETGEAR Expert
Hi Retired_Member
Could please confirm your original issues are resolved or not after the firmware update to FW 2.5.1.106? I see you are not seeing the devices in the attached device list page. List out any other issues with debug logs. Hope you have upgraded your SRS60 if any.
How to take debug logs:
1. Go to https://<Orbi Pro IP address>/debug.htm
2. Click on start capture.
3. Wait for the issue to happend before saving. ( give at least 5 min before savig debug logs)
You can upload debug logs into google drive or something similar and send me link via PM.
Thanks,
Raghu
Retired_Member
Mar 29, 2020Problem Solved!
Best of luck all.
