Old-Steve's avatar
Old-Steve
SXK30 ethernet cable between the router and satellite
I bought the netgear Orbi Pro wifi 6 mini router and satellite.
I have an ethernet cable running between them but I think they are connected via wifi.
I am using ethernet port 4 on the router and ethernet port 1 on the satellite.
I can see the satellite is on ch 157 in my wireless client list.
Am I supposed to specify something somewhere somehow?
I just don't see it.
I would rather use ethernet as the backhaul connection instead of wifi. Especially since the cable is there in place!
I think it would be faster and more secure and more reliable. I can see the LED on the satellite light up and go magenta from time to time and it kind of bothers me.
Any help will be greatly appreciated.
TIA...
  • plemans's avatar
    If they're hardwired in together, it should auto-negotiate to use that hardwired backhaul.
    If you log in through the browser, what is it showing for the link on the attached devices page?
      • plemans's avatar
        how exactly is it setup?
        Are you going from SXR---->SXS30?
        Or is there a switch in between?
        Or a modem/gateway device?
        What firmware is the router and the satellite on?
        What does it show if you (temporarily) direct connect the satellite to the router with a short 6ft cable?
ProSupport for Business
