mcnahum
Aug 13, 2021Apprentice
SXR80 . Devices don't get IP (DHCP on Pi-hole) since 3.2.6.102
I have multiple devices who have a really painful issue and this since I upgrade to 3.2.6.102.
They don't get IP address ... they got connected ( I think to the SXS80) to the wifi ... but no IP are assign
there is around 50 devices on the network and the lack of feature around DHCP & DNS pushed me to setup a Pi-hole device for it.
All was good until the upgrade to 3.2.6.102
as there is no easy way to do a net work trace there, is it possible to track on logs from the SXR80 to understand what is happeing?
- RaghuHRNETGEAR Expert
Hi mcnahum
Could you please let us know if those connected devices are IoT?
Please share the debug logs from SXR80 or SXS80 by logging into https://<ip address>/debug.htm
Click on start capture. Connect those clients until you see the issue. Then download the debug logs.
You can upload debug log into google drive or something similar and send me a link to download via PM.
Thanks,
Raghu
Your pi-hole is running dhcp?
are you using a vlan for any of your ports/devices?
What vlan is the pi-hole on?
