johnjeff1963
Nov 10, 2017Aspirant
I need remote support from NETGEAR for a R7000
My nighthawk router was hacked The IP address changed to 10.0.0.1 It’s name is now local host I renamed the networks and changed the passwords through The router login Then I was unable to access ...
DexterJB
Nov 14, 2017NETGEAR Moderator
johnjeff1963
Nov 18, 2017Aspirant
I found net gear support to be both outrageously expensive and completely ineffective
The support staff is filled with people from foreign country who cannot appropriately speak the language enough to help you problem solve your problem
And your help community since you in loops of constant repeat activity when you’ve already repeatedly done that step already
I have called you had a private service to take care of the problem
