rvwaal's avatar
rvwaal
Guide
Jul 09, 2017
Netgear Genie crashes
Hi,
Every time I launch backup, it genie timeline crashes.
Additionally, Readycloud cannot write to or download files to the external hard drive or 120gb flashdrive (NTFS formatted) plugged into the usb port. Files can be seen and new folders can be created.
I did try installing the old drivers per instructions provided in other discussioons, but nothing works.
Otherwise, the router works fine. I specifically purchased and paid extra money for a these features. I find the persistent problems with this software dating back several years problematic. Might be my last Netgear product.
router model: R6700v2
firmware: v1.1.0.38
win10, 32 bit
rca cambio tablet
Thanks, I appreciate any help.
  • michaelkenward's avatar
    michaelkenward
    rvwaal wrote:
    Hi,
    You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac application, or an Android iThing app.
    And what is "timeline crashes"?
    • rvwaal's avatar
      rvwaal
      Guide
      Hi,
      When I open Netgear Readyshare Vault, then click on the Backup tab, I get the following message: 'Genie Timeline has stopped working'. At that point, the program closes. I've reinstalled the software several times and tried installing the older drivers. Nothing helped.
      I'm running a Windows 10 tablet. No android or Mac software present.
      I'd appreciate any troubleshooting tips.
      Bob
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi rvwaal,
        I have sent you a message. Please check your inbox.
        Dexter
        Community Team
  • Like everyone else Netgear Genie crashes.  I spent some time going through the community files and these problems go back years.  Whilst there have been various fixes suggested, people continue reporting the same problems.   I would encourage Netgear and they do appear to read this forum to tell us how and when this problem will be fixed.   Netgear the floor is yours!
    Regards
      michaelkenward
      Nope. Works here.
      If you are referring to the desktop genie for Windows, Netgear has a habit of sneaking out new versions without telling us. It certainly does not provide an automated update process.
      So from time to time I go and get the latest version:
      genie Landing Page | Apps | Discover | Home | NETGEAR
      • rjsargeant's avatar
        rjsargeant
        Initiate
        Sadly I am using the latest version and I have even tried past fixes which reverted to earlier drivers.  Looking through other posts on the community site, there are a lot of users who are and have been experiencing similar problems for a long time.
        Regards
