fury88's avatar
fury88
Star
Mar 14, 2017
R8000 no longer connects remotely with Genie app after latest firmware
The Genie app was finally working the way it was supposed with pausing connections, etc but then I went an upgraded to the latest firmware and its hosed up Genie. It shows two routers now, one with a serial and one without. I can't connect to the one with the serial number anymore. The second one lists as R8000 (N/A) and doesn't allow remote access. Anybody have any idea what happened here? It's like the firmware upgrade created a duplicate router entry in Netgears DB and they don't match anymore. Please help!!
  • Should work, may work... but it does not. I think you've missunderstood the issue. No one is having a problem updating or accessing via Ethernet. It's that the Genia app DOES NOT work with the latest firmware.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi all,
      There is no update from engineering yet. Rest assured, this is being worked on.
      Dexter
      Community Team
      • Capster13's avatar
        Capster13
        Guide
        Is there any solution to this yet?  I can no longer use the destop application or the iphone/ipad applications.  I can only log onto the router via the webpage.
  • The Genie app is just a mess right now there are several threads of people having issues and they have done nothing about it. I have not been able to acces my parental controls thanks to the only being able to get to them through the app. This has been going on for months
  • In the mean time I will just have to keep catching my teenage son finding porn sites and infecting my computer because I can not access my parental controls!
  • No fix yet. All I keep getting told by Dexter is the engineers are working on it.
    • Holyevil75's avatar
      Holyevil75
      Initiate
      I also have the same problem after the update .Genie does Not connect .
      • ivhansen's avatar
        ivhansen
        Star
        1. Genie wont work as descibed
        2. Airplay is unstable
        3. Random lock/restart
        You may run an old and potentially vulnerable firmware (+1y old). Genie will work, but other problems may be related to that version. And you are of cause more vulnerable to cyber attacks.
        There is no reason to hope for a firmwareupdate as R8000 is now an older product in Netgears range. So you buy this products with the known flaws, that may or may not be critical to your use, with the well known and -documented support from Netgear.
