ninja661
Mar 05, 2018Luminary
Ready Share Vault cannot find the external USB drive
Ever since I upgraded to the most recent firmware on the R8000, I connected my Western Digital USB (1Tb drive) to the USB 3.0 port and I had to reinstall my desktop as it was having issues. Come to reinstall the ReadyShare Vault software and the drive attached to the router can no longer be found. I have reset the router, re-registered with Ready Cloud and I can find the drive the hard way via the routerlogin.net web site, but the backup software no longer sees the drive,, What happened? Am I alone in the mystery? I may as well, just start over, remove the ReadyShare software and go with a bare metal backup such as Acronis or go back to the really old Disk -> Tape archival .. at least I know it was reliable -- unlike so much from Netgear lately. I have told Netgear support that when I couldn't get the email reports sent to forget it, this is just one more stake in the coffin. If they can't get it right, the R8000 becomes a doorstop ... waste of $$$$$$ for something that is supposed to work.
Something to ask NG support about then on the phone...
ninja661wrote:Ever since I upgraded to the most recent firmware on the R8000, I connected my Western Digital USB (1Tb drive) to the USB 3.0 port and I had to reinstall my desktop as it was having issues. Come to reinstall the ReadyShare Vault software and the drive attached to the router can no longer be found. I have reset the router, re-registered with Ready Cloud and I can find the drive the hard way via the routerlogin.net web site, but the backup software no longer sees the drive,, What happened? Am I alone in the mystery? I may as well, just start over, remove the ReadyShare software and go with a bare metal backup such as Acronis or go back to the really old Disk -> Tape archival .. at least I know it was reliable -- unlike so much from Netgear lately. I have told Netgear support that when I couldn't get the email reports sent to forget it, this is just one more stake in the coffin. If they can't get it right, the R8000 becomes a doorstop ... waste of $$$$$$ for something that is supposed to work.
See if any of these suggestions help:
- ninja661Luminary
Tried that too! Reinstalling everything from the ground up. Tonight, tried resetting the router to factory defaults and some reason it wouldn't even reset with a HARD reset (by pushing the button on the back of the router!) The router *STILL* wouldn't reset. I am going to be brave and let a Netgear support person connect to the router via remote connection (not my first choice, because I have had the luck of where a 'Support Engineer' claims to know what they are doing and usually don't have a clue making the problem worse.
- ninja661LuminaryTried that, no luck. They recently updated the firmware for the R8000 to, but not sure if that’s the problem or not. First time I connected the drive all was great, now it sucks wind.
Try reverting to last working FW?
