RayVil79's avatar
RayVil79
MR^0 disconnecting
I have asked the tech support to install the product andhave issues of sattelite disconnect everynight. I have talked to them about help and have updated the firmware. It did not help at all. Tech support told me to move the unit closer to the router, and this did not help at all. Every morning I have to reconnect the unit.
Anyone have suggestion on how to fix this problem. It has been 6 months and need to get this work properly
  • plemans's avatar
    You have the MR60?
    What firmware is on it and the satellites?
    How big is your home?
    What materials are you interior walls/floors/ceilings made from?
    How far from the router is the satellites?
    How many satellites do you have?
    what modem/gateway is the router connected to?
    Is it only the satellites that disconnect? The router stays working fine?
    How do you know they're disconnecting?
    Details are key in help out.
    • RayVil79's avatar
      RayVil79
      Yes I have MR60
      Frimware    V1.0.6.112
      The house size is 2000SF
      wood stud, drywall, carpet floor material
      distance between 15-20 feet
      Modem is by verizon
      It is satellite that disconnect.
      The red or orange light is on at the sametime, my light controls is not accessible.
      The router is on the first floor  and the one satellite on the 2nd floor,
      the other satellite is on the first floor at the othe side of the house from the router
      • plemans's avatar
        RayVil79 wrote:
        Yes I have MR60
        Frimware    V1.0.6.112
        distance between 15-20 feet---they should be at least 30ft away from each other.
        Modem is by verizon---Verizon likes to use modem/router combo devices. What gateway is it? Is it in passthrough/modem only mode? otherwise you can be in a double nat?
        It is satellite that disconnect.---Just one of them? both of them?
        The red or orange light is on at the sametime, my light controls is not accessible.---Not sure exactly what you mean by this. What red/organge light?
  • FURRYe38's avatar
    What is the Mfr and model# of the ethernet switch in the configuration?
    • grajkovic's avatar
      grajkovic
      For my configuration, I'm using two Netgear switches (that worked fine for this Ethernet backhaul prior to mid-year firmware for MR60/MS60), but they are:
      Netgear GS108
      Netgear GS116
      What I *think* may be happening, I think that the EEE 802.3az "green ethernet" feature may be interfering with the most recent firmware builds of these devices - nothing else in my configuration changed - firmware upgrade for MR60/MS60 and "boom", Internet connection works for a bit, Ethernet backhaul to two APs, and then the link degrades rapidly.
      Remove one satellite, and the link is OK.
      Configuration goes:
      Modem --> GS108
      GS108 --> Satellite 1 (Currently Disconnected)
      GS108 --> GS116--> Satellite 2 (Connected)
      If I reconnect Satellite 1, things work ok for a few hours, and then BOOM, Internet connectivity becomes unrealiable - network connectivity "iffy".
      Ethernet throughput is WORSE than Wireless throughput - this was not the case before.
      So to resolve things in the interim, I've enabled Wi-Fi on all devices that I would otherwise Ethernet connect; not ideal.
      Before I scrap the architecture and get new switches - I want confidence in a solution before I throw money at the problem.
      • FURRYe38's avatar
        Netgear GS108
        Netgear GS116
        Configuration goes:
        Modem --> GS108 <Where is the MR60 in all of this? I presume it's between the ISP modem an your GS108 switch?
        Be sure all your cables are of good quality. CAT6 is recommended and it's not recommended to mixed older CAT# versions with newer versions. Keep with 1 CAT# version.
        Also might try newer FW version for the 60 series:
        https://community.netgear.com/t5/Nighthawk-Mesh-System/New-MK6x-series-MR60-MS60-FW-v1-1-6-122-Released/td-p/2162308/jump-to/first-unread-message
