polscifreak
Dec 15, 2022Guide
XR1000 2.4 Stops working
I bought an XR1000 a couple of years ago and haven't had any issues until recently.
For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router fixes it.
I've tried several firmware versions and have the same result.
Any ideas?
Any ideas?
polscifreak wrote:
For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router fixes it.What does "stops working" mean? The 2.4 GHz LED goes off?
Have you enabled smart connect? This will combine 2.4 GHx and 5 GHz onb to a single SSID.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - Netduma-FraserNetDuma PartnerHow often does it occur? Are you using Smart Connect? Do 5GHz and wired devices continue to work?
At this point, it occurs about every day and a half. All my devices on the 2.4 GHz channel go offline.
5 GHz and wired devices work just fine.
Rebooting the router restores connectivity.
I am not using smart connect.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How is the wifi settings configured?
What do you have connected to the 2.4Ghz radio?
Any ideas?- michaelkenwardGuru - Experienced User
FURRYe38 wrote:
Is there an echo in here?
For my modem, I'm using a Netgear CM1000v2.
WIFI Settings:
2.4 GHz
Enable AX
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Auto Channel
Mode: up to 600 Mbps
Transmit Power: 100%
WPA-Personal [TKIP] + WPA2-Personal [AES]
5 GHz
Channel:36
Mode: up to 4800 mbps
I don't seem to be having any issues with the 5 GHz band.
On the 2.4, I mainly have my smart home devices connected. Everything else I try to get on the 5. When the issue occurs, even my phone will not connect to the 2.4, but can connect to the 5.
In range, I only see two other wifi networks.
What happens if you disable AX mode on 2.4Ghz?
How many devices do you have on the 2.4Ghz network?
Do you need TPIK enabled on 2.4ghz?
Try channel 1 or 11 on 2.4Ghz
