Aen2025's avatar
Aen2025
Orbi rbr40 not connecting with modem
Hello,
I’m hoping someone can help me. I have an Orbi rbr40 router with two satellites. Motorola modem. I unplugged the router and modem four days ago to move something. Plugged back in a few hours later. The router appeared as it was loading- slow white blinking light. Then turned solid purple. I tried unplugging and syncing a few times.
Called Orbi, not sure if it was really Orbi. I called three different times, in sum they are saying there is malware. They said when I unplugged and replugged (prior to issue) that allowed malware thru and somewhere along the line of router, satellite or devices it is infected and I’d need to pay $349 for 5 years (maybe 3, can’t remember) or $499 for lifetime security protection. They said they clean up the malware and fix the issue. I don’t buy it.
i have since done a factory reset, no help. I called Xfinity today, there is no issue with signal getting to modem. And YouTube says my modem is working fine. The router is now solid white light.
of course Xfinity tried to have me rent a modem/router.
any help, in simple terms, would be greatly appreciated. My soon to be ex husband was the tech guy- he skipped town to his new life and this is all foreign to me.
Thanks a million in advance
  • CrimpOn's avatar
    CrimpOn
    There is a good chance that the RBR40 is not actually connected to the modem.
    Can you check that the cable connects the RBR40 WAN port (yellow) to the modem.
    Turn off both modem and RBR40.
    Turn on modem and wait a few minutes (not seconds... seriously... minutes)
    Then turn on RBR40
    • Aen2025's avatar
      Aen2025
      The yellow port marked internet is connected to a 2x2x1 or so white box. On back of said box is Lutron wireless L-Bdgpro2.
      on the modem, a Motorola surfboard 6141, there is a spot for power, cable like connection, and Ethernet.
      the only thing I disconnected when moving was the power cord plugged into an extension cord.
      I have left all off for more than minutes, a few times.
  • FURRYe38's avatar
    What model # is the current ISP modem?
    Make sure the ISP has check it all out up to the modem.
    Connect a wired PC to the modem directly to see if modem is actually working good.
    Contact the Mfr of the modem for there help and information regarding there product.
    ISP is responsible for all services up to the modem.
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    • Aen2025's avatar
      Aen2025
      It’s a Motorola modem surfboard 6141. I have called Xfinity (ISP) and they indicated everything was fine on their end and felt no need to send a tech out.
      I don’t have a wired pc. Only a Mac.
  • CrimpOn's avatar
    CrimpOn
    p.s.
    No. That was not Netgear Support.  Here is how to contact Netgear after the 90 days of 'complimentary support' provided with a new purchase have elapsed:
    https://www.netgear.com/home/services/prosupport/
    Notice that Netgear prices are not what you were quoted by (whoever that was)
