case44's avatar
case44
Cannot access Orbi AX4200 anymore
I have the
Orbi AX4200 WiFi 6 High-Performance Router (RBR750)
I used to be able to either go to orbilogin.net or use the Orbi Android application to manage the device.
Now, even after multiple power cycles, I cannot access the device. Any IP or url I try doesn't connect and the Orbi app says "No devices available".
However, both my wifi and internet are working fine.
Any suggestions?
  • Thanks, the IP of my Orbi (on my ATT) is 192.168.1.64.
    The IP of my home machine is 10.0.0.2 (on the Orbi).
    I tried 10.0.0.1 and 10.0.0.254 as well
    When I go to orbilogin.com I get ERR_CONNECTION_REFUSED
    • StephenB's avatar
      Then 10.0.0.1 should connect you to the Orbi's web page, and 192.168.1.1 should connect you to the AT&T gateway's web page.
      Are you also getting this with 10.0.0.1?
      A reset might be needed.
  • Correct. I'm wired to the Orbi RBR750 and 192.168.1.1 isn't getting the web page to come up.
    I've got AT&T Fiber Model: BGW320-500
    I've got the wifi turned off on it. It's directly connected to the Orbi for my home network.
    I was hoping to avoid a factory reset, but looks like that's the route I need to take.
    • StephenB's avatar
      Before you do a massive reconfiguration, you should check that your PC IP address is on the 192.168.1.x subnet.  If it says something else, post back the address.  Note that the LAN addresses are private (not internet routable), so it is safe to post them.
      FWIW, double-NAT isn't as dreadful as some here always say, so if your internet has always worked before, then there is no reason to change anything.
    • FURRYe38's avatar
      Your ISP modem already had a router built in. Might check the connecting PCs IP address it gets from the Orbi router and see if maybe the IP address changed to a 10.x something address. if not, then Ya, reset will be needed.
      FYI,
      Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
      Couple of options,
      3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
      Static IP Address Configuration for AP Mode | NETGEAR Communities
      https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
      Try option #2 first...
  • FURRYe38's avatar
    So using a wired PC and web brower pointed at 192.168.1.1 isn't getting the RBRs web page to come up?
    If not, then you might do a factory reset on the RBR by pressing the reset button in back for 15 seconds then release. Give about 5 minutes then with one wired PC and web browser, walk thru the setup wizard:
    https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
