ScottNH
Mar 06, 2026Aspirant
Cannot Connect to Orbi
We had a power glitch, and after recovery, I suddenly cannot connect to my RBRE960 router (or satellites). The router is working, and I have both WiFi and internet, but whenever I try to connect to the router, via either my browser ("192.168.1.1 refused to connect") or the app ("Unable to connect to router"), it fails. The funny thing is, on the app, under "My Products," it shows a green dot next to my router and "Connected via Anywhere Access."
I've restarted the router and modem multiple times, but still no-go. Restarted the computer, etc. Still no-go.
My setup:
RBRE960 router and 3 RBSE960 satellites
Nighthawk CM2050V Cable Modem
Appreciate any insights anyone can give.
Thanks.
The nuclear option worked. Have no idea why it was necessary, but resetting to factory default and climbing my way back to my own settings finally worked. Daylight savings time saved me, because everyone was still in bed. "Hey, Alexa isn't working!" Well, almost everyone.
- ScottNHAspirant
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Glad it fixed it but it sucks when you have to go nuclear. A backup is always a good option to have available. I switch routers enough that its probably only 5 minutes of setup through the gui when I do it.
What is the IP address of the PC you are testing with?
- ScottNHAspirant
Desktop (hardwired): 192.168.1.60
iPhone: 192.168.1.14
iPad: 192.168.1.61
Laptop (WiFi): 192.168.1.66
The odd thing (one of the odd things), is that even though I get the "unable to connect to router" message on the screen, if I hit "Device Manager," I can see the 63 devices connected to the network.
I'm afraid I'm going to have to go to the nuclear option and factory reset. I can hear the family yelling now...
Did you try a factory reset/reinstall? Maybe something was corrupted in the power glitch
If the Orbi LAN does not have IP 192.168.1.1, then of course it cannot be reached at that IP address.
Since the Orbi app does connect using Anywhere Access, please navigate to the router "Details" tab and scroll to the bottom line.
What IP address does it show there?
- ScottNHAspirant
Here's my challenge: after working flawlessly for 18 months at that IP, it seems to have "burped" after the power glitch. Some of the functions work, or seem to. Here's what I mean.
I can't reach the router to see the "details."
For some reason I can't embed the screenshot I'm trying to show. I'll try to attach it.
For description, at the bottom of the screen that shows
- ScottNHAspirant
the router with the green dot and "Connected via anywhere access" it shows "Unable to connect to router," so I can't view the router details to see IP address.
And now it appears I cannot even attach the screenshot...
Do other devices have same issue or only this one PC?
Try powering OFF the CM modem and RBR for 30 seconds then back ON.
Check your PCs networking settings.
- ScottNHAspirant
None of the computers (laptop or desktop) can reach the router at 192.168.1.1.
I've powered off/on the modem/router numerous times, in every sequence you can imagine.
It might be useful to double check that the router is still defining the LAN with the same IP subnet (192.168.1.x)
Open the network settings of a device connected to the system and look up
- The IP address that has been assigned to the device.
- The IP address of the internet "gateway".
If the gateway is not 192.168.1.1, then that is the reason it does not appear there.
- ScottNHAspirant
I just checked, and I on my iPad, iPhone, laptop (all WiFi) and desktop (hardwire to the router), I get an IP of 192.168.1.x, and they all show the default at 192.168.1.1 where it should be. It's really puzzling (and frustrating).
