LameGoose's avatar
Dec 05, 2019
Chromebooks refuse to join Orbi WiFi 6 network (AX6000)
I just configured my new WiFi 6 Orbi AX6000 (RBR850 + RBS850), and my Lenovo C330 units (x2) fail to join the network.
All of my other devices connect and perform without issue (mostly Apple devices, HomeKit accessories, and NestCams); unfortunately, these Chromebooks are the outliers.
When I attempt to join my network, I get a generic “unknown” error from Chrome OS, and connection fails.
Things I’ve tried:
-Power-cycling the network (modem and Orbi)
-Wired and wireless configuration of the satellite
-Removing the satellite entirely
-Changing encryption to WPA/WPA2 from WPA2 only
-Updating firmware:
-RBR850: V3.2.8.5
-RBS850: V3.2.8.5
My Chromebooks had no issues with my previous mesh setup (Amplifi HD), and I can currently connect them to my phone’s personal hotspot (workaround so the kids can complete their school assignments).
I know folks have seen similar issues with other Orbi setups, but those threads just kind of died with no real resolution.
Is anyone else currently experiencing this behavior? Thoughts and suggestions welcome.
  • We have a fix! My Chromebooks are finally connected.
    1. Login to orbilogin.net.
    2. Click ADVANCED Tab, on a far left panel click on ADVANCED option and then select Advanced Wireless Settings under it.
    3. Change the CTS/RTS value to 2347 then click APPLY button to save the settings.
    4. Then, try again connecting your Chromebook to the wifi network.
    Note: After I did this it did not work right away. I forgot the network on the Chromebook and restarted the computer than tried to connect and bam I'm connected to the Orbi. Keep you posted if I have any drops but working as of now.
  • Do the books connect if you temporarilly disable WPA security on the RBR? Re-enable WPA2 and AES only after testing this.
    What channels are you using? Auto? Try setting manual channel 1.
    What happens if you disable AX mode?
    • LameGoose's avatar
      LameGoose
      Tutor
      Just tried a few more things—starting with disabling AX (it would be nice if the Obi app supported the ability to do this). Chromebooks still refuse to connect.
      Then I effectively started from scratch:
      -Changed SSID
      -Set encryption to None
      -Disabled AX
      -Rebooted router
      My Chromebooks were able to see the new SSID; however, attempts to join result in the same behavior.
      I haven’t played around with my channels yet. 2.4GHz is set to Auto, while 5GHz is set to 48.
      At some point I’ll get around to contacting both Lenovo and Netgear support. I’m wondering if there’s just a compatibility issue with Orbi and the network cards in these particular Chromebook models.
      • FURRYe38's avatar
        Guru
        Ok, If there not connecting with AX and WPA disabled, then there is a compatibility issue. I presume it's with the WiFi adapter drivers with in these books.
        I would start with Lenovo first. You can collect debug logs if you want to during the attempted connect with the book by going to 192.168.1.1\debug.htm and starting the logging process. Then attempt to connect one of the books to the system. After it fails. Select the Save Logs button. Have these ready for NG to review.
        Open a ticket here:
        https://www.netgear.com/mynetgear/registration/login.aspx
        Afix the logs to the ticket.
  • Any luck with this? I've reached out to Netgear, Lenovo, and now Google. My Chromebook still won't connect. Netgear says to update wifi card (this can't be done on Chromebook). Lenovo says to contact Google. Google doesn't have the greatest support. What else can we do? I might just have to set up an old router for this 1 device.
  • Hello, please check your wifi is in secured mode(wpa wpa2) if it is in open mode, i think the chromebook will refuse to connect. I have the unsecured satellite wifi issues for my rbk852.
    • Eroach's avatar
      Eroach
      Guide
      Yeah I tried everything. Turning off security. Also tried WEP, WPA2, and WPA3. Also tried turning AX mode off.
      • FURRYe38's avatar
        Guru
        Did you try and disable AX mode while leaving the wifi security open?
        Seems like a problem with the Chrome book and NG FW if the chrome book won't even connect with security turned off.
        I would open a support tickect with NG and Google and see if something can be done. The wifi drivers between the Chrome book and Orbi AX needs to made compatible.
    • FURRYe38's avatar
      Guru
      Awesome fix. Glad that worked. Thanks for sharing this information. Hopefully it will help others.
    • Druizer's avatar
      Druizer
      Initiate
      BINGO!  Very easy fix.  I was about to hook up my old orbi RBR40 just for the Chromebooks.
      • FURRYe38's avatar
        Guru
        Glad that worked. THanks for confirming it worked for you.
        Enjoy. :smileywink:
    • DSummer68's avatar
      DSummer68
      Initiate
      This worked great, thank you for letting us know what the fix was. YOU ROCK!
      • FURRYe38's avatar
        Guru
        Enjoy. :smileywink:
