joshadam1984
May 07, 2020Aspirant
Firmware v3.2.10.11 Frequent Disconnects
Hello. Over the past couple months I’ve noticed frequent disconnections from a couple of my RBS850 satellites. I have three satellites in all.. with a stand-alone modem (Only) and the RBR850 as my router.
I took the feedback from other posts and downloaded a much earlier firmware version yesterday evening, did a hard reset, and started fresh.
Unfortunately, the system updated over night last night on its own back to V.3.2.10.11.
When I noticed that this morning, I once again did a hard reset on the router and satellites. I’ve hard the “updated” system running for 3 hours now and maintains frequent disconnects from the RBS850s.
Everything worked seamlessly up until about the middle of March.
Any recommendations or assistance is appreciated. Also, I did go back and update the thresholds to the 2347 value.
Thank you.
Thank you.
Any Wifi Neighbors near by? If so, how many?Have you loaded v11.2 on everything then factory reset and setup from scratch, set CTS/RTS values to max then see if problem reappears?
- joshadam1984AspirantI haven’t adjusted the channel— it is auto currently so will try changing it.
Wifi neighbors— normally 1 sometimes 2 show up.
One is more then 30 ft, blue does flash blue when syncing.
I did a factory reset after it automatically pushed the firmware back to v3.2.10.11.
CTS/RTS were changed and all Orbi systems rebooted.- FURRYe38Guru - Experienced User
Try v11.2 if needed.
- joshadam1984AspirantI should all that none are wired.. all wireless. When synced, they flash blue.. which I understand is a good connection.
- Sevo123ApprenticeIm on version 3.2.11.2 and my devices are disconnecting constantly its so annoying! I regret buying my rbk853 and giving netgear $1000 smh !!!! Do upset that they cant fix this stupid disconnecting issue. Before on my rbk53 unit they did the same thing in the beginning then finally fixed this situation now a new product and new problems... Their phone support is garbage now. They cant even help
Sevo123 wrote:
Im on version 3.2.11.2 and my devices are disconnecting constantly its so annoying! I regret buying my rbk853 and giving netgear $1000 smh !!!! Do upset that they cant fix this stupid disconnecting issue. Before on my rbk53 unit they did the same thing in the beginning then finally fixed this situation now a new product and new problems... Their phone support is garbage now. They cant even helpIt is certainly frustrating that your home network is not reliable for you. Do you have a posting where you can describe your issues and get community assistance? I think everyone's situation is different so we cannot assume that one person's disconnects is the same as another's
I've been fortunate and my AX system has been great with both 3.2.11.2 and the prior 3.2.10.11. Once I changed CTS/RTS to 2347 (thanks FURRYe38!) then things worked as expected.
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
