MAS47's avatar
MAS47
IOS 26.3 Upgrade - Can not connect to Internet but connected to the ORBI WiFi Network
On  V7.2.8.2_5.1.18.  Frustratated no amount of reverting to factory defaults will alow me to connect to the interent even though I can connect to the WiFi network and do anythign I want to config the ORBI settings from Iphone and iPAD.
Followed all Netgear known KB's and Apples KB's.
When will a firmware update be available because no amount of factory default resets and config options will allow my device to get to the internet?
  • MAS47's avatar
    MAS47
    Feb 26, 2026
    The Roger’s router is an CGM4981RG.  Not too helpful looking it up but seems to be a 6/6E device.
    I see the 7.2.8.5 FW release, have to load it manually, auto settings say I’m upto date.
    yes I’m in Cacada and maybe that’s why the new FW is not showing.
    will let you know my results.
  • FURRYe38's avatar
    Checking this with my RBR960 on FW v7.2.8.5 and my iPhone 17 with iOS 26.3 loaded.
    Phone is connecting to the RBR and getting internet services thru the RBR:
  • Did the Network Reset as it's the simplest to do without going the full nine yards without a backup.
    RBR firmware is V7.2.8.2_5.1.18 latest.
    It's the Rogers one, newest, Don't have details handy,  but just fixed the speed by using port 4 with the red bar which is for Fiber speeds because I was getting choked at 700-800Mbs now cranking 1700-1900Mbs
    IPV6 disabled
    ISP DNS, I used to use custom but that was causing other issues
      • MAS47's avatar
        MAS47
  • Amended Details:
    IOS 26.3 (iPhone 13 Pro Max/iPAD Pro M2) ORBI RBKE963 w/2 Sats
    When I work with devices I'm 2-3' away from the router unit on WiFi and use a MacPro / Windows machine for wired access into the router to manage configs.
    Armour:
    Removed VPN setting and disabled.
    Finally removed it.
    iPhone settings disabled:
    Private WiFi
    Limit IP Address Tracking
    Wifi Assist
    Procedural:
    Forget and Reconnect to WiFi
    Reset of Network settings
    ORBI:
    Factory reset - reconfigure defaults for access
    After many combinations of the above no device running IOS 26.3 can reach the internet but they can connect to the WiFi successfully and appear in the access control table.
    If I could down grade I would cause when I get into a trouble shooting cycle everyone gets annoyed with me.
    Phone is back typical secured settings cause I have to work, but next round when I have time will be to backup the phone and iPad and reset to factory defaults.
    I have disabled other iPhones and iPads from upgrading to 26.3 otherwise there will be a revolution in the house.
    My other question is:  Is there a debug mode in the ORBI software I can use to see what's it's doing to make it's connection and see what it failing on?  Would make life so much easier, all this autoconfigure stuff doesn't allow for me to control the vertical.
    • FURRYe38's avatar
      Something to try on your iphone instead of doing a full on factory reset. Try the Network Reset instead. I happened to try this on my Iphone 12 a couple of years ago. Iphone was having problems printing from photos app to a wireless connected printer with the phone. Would print correctly from Safari but not the photos app. Went thru all kinds of troubleshooting thinking it was a printer issue. I happended to try this Network Reset on the iphone and BOOM, photos app started printing correctly to the printer.
      This almost sounds like a iphone or iOS issue as the iOS was recently released from Apple as well.
      Is IPv6 enabled on the RBR?
      Using ISP detected DNS or custom DNS?
