frekin
Jun 02, 2025Aspirant
Issues with an RBR850 (router mode) and one single RBS850 connected wirelessly
I have remarkably similar issues with an RBR850 (router mode) and one single RBS850 connected wirelessly.
- Hitron CODA56 DOCSIS 3.1 cable modem on ostensibly gigabit cable service. Cable modem never shows a change in status
- v7.2.7.15 on both devices, successfully updated
- CAT8 cable between modem and router WAN port
- At least 30 ft line of sight with a few walls between RBR and RBS (2600 sq. ft house)
- Several devices connected directly via ethernet
- I've tried 2.4 GHz channels 1, 6, and 11 and all the allowable channels on 5 GHz
- I've enabled and disabled logging and all the other settings that have recently been mentioned in this forum
Every day, the router randomly cycles between good and bad speeds measured via Orb app on my iPhone 16 Pro Max. Every day, I experience momentary loss of internet connectivity at random times, usually for less than 5 minutes. When I had logging enabled, I saw nothing suspicious before these events, then I saw a flurry of DHCP requests as everything rejoined the network.
Please help. None of the suggestions I've seen in this forum for similar problems actually solves anything. They are just a way to whittle around the problem.
At least tell us if this is a known issue with the latest firmware because this is driving me crazy.
Final update:
I scheduled 2 additional visits by cable company technicians to check my street's cable hub and my home's drop. Finally, I got a supervisor-level technician who correctly identified a problem with the line extending from the drop into my house. He replaced the line after the drop, and I replaced additional lines within the attic; the RBR850 has now functioned without any issues whatsoever for over a week.
I now get the rated transfer rates and consistently low pings in every device I've tested via wifi (close to RBR) and ethernet. This was clearly an issue with the cable lines. Kudos to the gurus in this forum for calling it correctly from the beginning.
- frekinAspirant
I forgot to mention:
- All devices connected directly to the RBR850 via ethernet go down at the same time as the wireless devices. It's as if the router or satellite just completely stop responding briefly, then come back to life.
When the Orbi 'app' reports a Speed Test, the actual Test is performed on the router. It is common for network speed to vary over time. It would be helpful to see actual numeric values for these Speed Tests.
A complete loss of internet should be reflected in the Hitron modem diagnostics that can be retrieved by the cable provider Many users have reported that cable technicians examined their cable drop and found issues with cable connectors or actual physical damage to the cable itself. (Squirrels apparently enjoy chewing on cables.) It might be appropriate to contact the cable company.
Who is your ISP your connected with?
Is IPv6 enabled on the RBR?
Be sure to run speed tests with a wired PC and Ooklas installable speed test app for best speed test results.
Does this happen with the RBS turned OFF?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR CommunitiesHas a factory reset and setup from scratch on the Orbi system been performed since last FW update?
Mine ran for 30 plus days with good operation on this version of FW.
- frekinAspirant
I think a physical cable drop issue is the most plausible explanation for the randomness I'm experiencing. However, it doesn't explain why I never saw this behavior until I replaced my last router (Nighthawk X10) with the RBR850/RBS850.
I'll contact the cable company and report back here. I suspect they will require an in-person visit, but it has been over a decade since anything has been inspected so this should be interesting.
The app I used is to check connection quality is "Orb": https://orb.net.
Get with the ISP then and have them check everything up to there equipment.
- frekinAspirant
Alright, I just completed my cable ISP service visit. He checked the drop at the access box across the street (OK, no problems), then he checked the connection point at my house (OK, no problems), and finally he checked the cable connection at my cable modem inside (OK, full speed available).
Now I am seriously confused and leaning toward this being a router issue at this point. I have noticed over the last two weeks that my top download speed is also always 90-100 Mbps no matter how I measure it: via 5Ghz wifi-connected device, via direct ethernet-connected device, etc. I have tried every possible way of measuring the speed, and regardless of which device or connection type it always maxes out at 90-100 Mbps. This wouldn't be a problem necessarily except that I pay for 1Gbps down / 100 Mbps up. Also, I get ~100 Mbps upload everywhere via the same testing methodology, so something is restricting only my max download speed.
I did the following today:
- switched the cable between cable modem and RBR850 to Cat8 - no change in behavior, though I haven't seen a network outage so far
- reset my RBR850 to factory settings, onboarded it, and restored previous settings - still limited to ~90-100 Mbps
- connected an old computer via Cat8 cable directly to modem: dl now >400Mbps (computer ethernet card is likely the bottleneck)
I am out of ideas here. Not only is my connection unstable and prone to going dead randomly, but it appears that my download speed is being throttled even though I have not set a bandwidth limit in the router interface.
Interestingly, the last time I ran speed test within the Orbi interface it returned 1 Gbps download. This was prior to the firmware "upgrade". The cable company confirmed that I am capable of this speed, showing me >900 Mbps at the same endpoint today. The router seems to be the problem.
I'm just going to bite the bullet and buy a different router today to see if all these problems are fixed.
I would have not reloaded the config file after a reset is performed, may have introduced something...Factory reset and setup from scratch with out loading the back up config. Just walk thru the setup wizard and get to the home screen, don't enable anything. Can leave the wifi SSID default while you test, then change back to what you need after testing.
- frekinAspirant
Cox cable internet: 1 Gbps down / 100 Mbps up
No, I have never enabled IPv6
I installed the local app before next steps.
Today, the RBR850 router had already gone brain dead and lost wifi at least twice in the first half of the day.
I reset the RBR850 once again and onboarded with all the default settings, but did not restore settings or change anything.
Speed test results
- On router configuration "Speed Test" page: ~90-100 Mbps down / 10 - 15 Mbps up (!)
- Looks like the upload is even slower today. Unfortunately I didn't check just before the reset, but this is 1/10 my rated speed!
- On windows app using a computer connected directly to router via CAT6: ~90-100 Mbps down / 10 - 15 Mbps up
- On iPhone 16 Pro Max, connected to 5GHz wifi: ~90-100 Mbps down / 10 - 15 Mbps up
Something is clearly wrong with my RBR850 + RBS850 setup.
Next, I restored all my previous settings and got identical results as above.
I also received a TP-Link BE800 WiFi7 router today and onboarded it immediately after the actions above, with all the ethernet cables hooked up similarly. I didn't change anything else in the network, including the modem.
Speed test results for TP-Link BE800
- On windows app using a computer connected directly to router via CAT6: ~950 Mbps down / 115 Mbps up
- On iPhone 16 Pro Max, connected to 5GHz WiFi: 1100 Mbps down / 115 Mbps up
- On iPhone 16 Pro Max, connected to 6GHz WiFi7: 1200 Mbps down / 116 Mbps up
This appears to be the nail in the coffin for these RBR850/RBS850s. I might continue to explore troubleshooting, but I have wasted 10s of hours at this point and I have to assume either the hardware is bad or the latest firmware really screwed something up. I'll keep checking these forums to see if something official happens with the Orbi WiFi6/6E just so I can keep the devices as backup.
- frekinAspirant
Final update:
