  • Dang it, no editing my own posts? I forgot to mention I had v7.2.7.15 firmwares before upgrading. I didn't reset or change anything. I did back up my settings just in case.  So far, nothing broke. I doubt it will fix my random rare wifi connection drops though when I move around.
    • FURRYe38's avatar
      You can follow this for doing Manual upgrade if Auto Update doesn't find or post any new updates on your system:
      Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
      Would need more details on randome wifi drops.
  • Since it is a quiet morning and I will be busy again later, I risk in upgrading my 750 router and its two satellites. Is it me or is http://192.168.1.1 have an annoying way to do manual upgrades? Why can't I upgrade all of their firmwares at the same time especially when I checked both satellites to manually upgrade? Are the other models like that too?
  • https://www.netgear.com/about/security?_ga=2.232076316.241849746.1763397952-576689976.1746563026
  • Who is using it in 750 model? Is it safe? ;)
    • KMDonlon's avatar
      KMDonlon
      Virtuoso
      Safe? Yes I suppose...but you won't have IPv6 if that is something important to you?
  • FURRYe38's avatar
    Updating this thread to show that RBK750 and RBK860 series FW was released last friday on this version of FW.
    Updated main FW update post to reflect this.
  • Can confirm that I am still seeing this issue (intermittently) under the latest firmware 7.2.8.2. Also with the RBS connected directly to the RBR, no switch between the two.
    When the problem occurred I checked the IP address it had been assigned and it was in the 169.254.xxx.xxx range, suggesting the issue is with IP allocation. This particular device is set up to receive a static IP address from the Orbi so this should not be happening.
    As before, the problem only seems to occur when moving to a wired backhaul satellite, and is very intermittent (once every couple of days at most). I've only personally observed this with an iPhone but then most of my other devices don't tend to roam around the house in the same way my phone does.
    • FURRYe38's avatar
      And if RBS are BOTH Wireless connected is this problem seen?
      How is the one RBS ethernet connected to the RBR? Directly behind the RBR or is there any kind of LAN switch or wall patch panel or jack in between them?
      Is this issue seen if you turn OFF one RBS?
      Will need to have someone near you help you figure out the home size in sq feet.
      If your house is old and seem to block good wifi signal, this maybe a building materials issue since you seem to be seeing this accross all FW and iOS versions. Any older homes with crecrete/steel or plaster and steel mesh, will be problematic for any wifi system.
      We will work on your issues in this thread. Thank you.
      • Garwoofoo's avatar
        Garwoofoo
        Apprentice
        Thanks FURRYe38​ , I appreciate your time with this one and I understand that you need to go through standard troubleshooting processes but some of these I think are red herrings. This issue with iPhones and ethernet satellites has been reported by myself and others going back at least three years so I am pretty sure it is not specific to my house. Most importantly - I and others have confirmed that switching both satellites to a wireless connection instantly resolves the problem, regardless of any other environmental factors. So I am convinced this is a long-standing Orbi bug.
        However I will try and address some of your other points. The RBS ethernet is connected via a wall socket (it was professionally installed as the cable runs down the outside of my house and in through the lounge wall). However I don't believe there is any issue with this as multiple other devices are connected via this socket including gaming devices etc where any interruption in connection would be immediately noticeable.
        I'll test what happens if I turn off the other RBS - although this will impact the wifi connection in my son's bedroom so I may not be able to do this immediately, I will need to wait until I have a good opportunity to try this out.
    • FURRYe38's avatar
      Is IPv6 enabled on the RBR?
      What iOS is on the iPhone?
      How is your RBS connected to the RBR? WIreless or ethernet?
      How many RBS are you using and size of home please in sq feet?
        Garwoofoo
        Apprentice
        My ISP doesn't support IPv6 and it is disabled on the RBR. The iPhone is using the latest iOS (26.1 at time of writing) but I've observed this exact problem on multiple iOS versions and Orbi firmwares going back at least five years now. The problem has existed as long as I have owned the system. I have Private Wi-Fi Address and Limit IP Tracking turned off in the phone's network settings, as per previous guidance.
        I have two satellites, one wireless and one ethernet. As per our conversation in the other thread, my wired RBS is connected directly to the RBR with multiple other devices connected via a switch plugged into the RBS. Previously I had the switch between the RBS and the RBR and the problem was exactly the same, i.e. changing this over hasn't affected this issue. The problem only occurs when moving TO the ethernet satellite from one of the other two connections - and it doesn't always happen, i.e. it's not reliably repeatable. However switching the ethernet satellite to wireless does resolve the problem (I don't want to have to do that though).
        I'm afraid I don't know how big the house is, it's an old house on three stories and the satellites are quite carefully positioned to eliminate blackspots owing to solid brick walls which are quite effective at blocking wifi signals.
        I've reported this a few times throughout the years (as have others), it's always one of the first things I test when upgrading the Orbi firmware and it always seems to be the same.
  • Ran it for about 24 hours, dropped my IPv6 connection again. Same issues as .15
    Back to downgrade to version v. 7.2.6.31
    Unbelievable 😞
  • Be careful with this one: 7.2.8.2 seems to have broken my wired satellite. It connects to the Orbi network as expected and shows up in the app with the correct details but no devices will connect to it. Anything that switches to that satellite immediately loses connectivity to the network.
    Router connections and my other (wireless) satellite seem to be working OK.
    Will continue trying to troubleshoot but would advise everyone to hold off on this one for now.
      Garwoofoo
      Apprentice
      Some more details in case anybody has any ideas.
      The satellite works fine when connected via wireless backhaul (as it always has).
      As soon as I connect it via Ethernet cable, any devices that try to connect to it immediately drop off the network. I can't get any devices to stay connected to that satellite at all.
      Anything that is connected to the satellite before I connect the Ethernet cable STAYS connected and continues to work. Which makes me think that the problem is perhaps with DNS allocation or similar.
      This setup (one wired, one wireless satellite) worked fine in every previous Orbi firmware version and nothing else about my setup has changed apart from this firmware upgrade.
      I didn't do a factory reset before upgrading from 7.2.7.15 (and, frankly, don't really want to go through the hassle) but I followed good upgrade advice (satellites first, then router, followed by a full power cycle) and that has always worked for me in the past.
      • FURRYe38's avatar
        When the RBS are ethernet connected, are they connected directly behind the RBR or is there any kind of LAN switch in between then? If there is a LAN switch brand and model please.
