Shadowgent's avatar
Aug 09, 2020
Orbi RBK753S AX4200 - Nest Thermostat Battery Drain
Installed new system a couple of weeks ago, and Nest thermostat keeps disconnecting from network due to battery drain.  I had other ax and wifi 6 systems and never had this issue.  Is there a fix in the works for this?
  • FURRYe38's avatar
    What FW version is currently loaded?
    What generation is your NEST controllers?
    What is the distance between the RBR and RBS?
    What is the distance between the RBR/RBS and NEST controllers? In Feet please.
    What is the CTS value your using on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
    Please review this and give a try:
    https://community.netgear.com/t5/Orbi-AX/Nest-Thermostat-Batteries-LOW-on-a-new-ORBI-AX-setup/m-p/1957035/highlight/true#M5829
    • Shadowgent's avatar
      Shadowgent
      Tutor
       - V3.2.15.25
      - 3rd Gen thermostat
      - RBR and RBS are each on different levels of house, so I'm not sure how to answer that.  RBR is on main level, same level as Nest controller.
      - 30 feet
      - 64
      Appreciate any help you can provide!
  • Identical issue with my newly installed Orbi AX4200 system.  I have 3 Nest Gen 3 Thermostats that have worked fine for the past 3-4 years on my Xfinity Gateway.  Once I installed the Netgear Orbi AX4200 system, all three Nest Thermostats have experienced battery drain issues (not using a C wire on Thermostat) that results in them dropping Wifi connection.  All three were connected via 5GHZ channel.  I have since set up a separate wifi network using the older Xfinity Gateway’s 2.4GHZ channel with a different SSID to connect the 3 Nest Thermostats.  All 3 Thermostats are again working fine. Running two different WiFi networks in my house is really not ideal, but is the only way I could get the Nest Thermostats working correctly.  Would really like either Nest or Netgear to come up with a fix for this issue.
    • FURRYe38's avatar
      What FW/SW version is loaded on your NEST controllers?
      FYI, I'n on v22 with my 8 series and 2 RBS. Using manual channel 1 and 40. CTS at 64. I have not seen any issues with my 1 3rd gen NEST since last year.
      Also please open a support ticket with NEST and NG regarding this.
    • Terry8166's avatar
      Terry8166
          i have a nest thermostat Gen 3 that has worked for 1,5 years on google wifi router and erro router.   this week iinstalled the orbi rbr750 ax4200.  i am very plesed with the speed and stability of this router. However there is one major issue that i see many wiht this router having OFFLINE LowBattery.   I just wanted to add my voice to the choir,   I am very frustrated with this issue.  This is not a cheap router and i would expect better support form netgear on this issue. Yes i have a ticket open.   The only way i have been able to solve this issue was to connect my Google wifi as a stand alone connection for my nest thermostat.   no more low battery issues.
      The good news is i got this router form Costco and i will retrum it an try our a different Wifi 6 router if netgear cant get this issue fixed.
      • FURRYe38's avatar
        https://community.netgear.com/t5/Orbi-AX/Nest-Thermostat-Batteries-LOW-on-a-new-ORBI-AX-setup/m-p/19...
        FYI, I'm on v12 with my 8 series and 2 RBS. Using manual channel 1 and 40. CTS at 64. I have not seen any issues with my 1 3rd gen NEST since last year.
      Terry8166
        I used your suggestion,  connected my old mesh router (google wifi using just one puck)  problem solved.  But not really.  The kind of money i paid this should not be an issue.
