g60919
May 24, 2026Aspirant
Orbi RBK760 firmware issues
i have a Orbi 760 with 2 satellites , recently i updated the router to newest firmware V6.3.8.11_1.4.83 , now all control functions not working , sleep time , pause internet or security options all not functioning , plus once i reboot i have to setup the network all over again !!
i tried to downgrade to previous firmware but even that not working ,
i need a solution to revert back to earlier firmware that at least works when i reboot !
help please
You can use the RBS self service web page to either downgrade or upgrade the FW directly to there web page. Then once that has taken, upgrade or downgrade the RBR.
Orbi Satellite (RBS) Self-Service Web Page Access | NETGEAR Communities
Yes, please do a factory reset and setup from scratch to make sure all is working after either up or downgrade.
Can follow this guide for that:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
- g60919Aspirant
Yes correct , smart parental controls not working at all
I have tried to upload firmware to sattelite but it keep redirecting to blank page , or page isn't loading
I managed now to downgrade the router , but satellites stays at higher version
any approach to
resolve ?
