MS_1234
Jun 25, 2022Guide
Orbi RBRE960 constantly disconnects/connected with out internet
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, eufy cameras, etc.
MS_1234 wrote:
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, eufy cameras, etc.I haven't had any "No Internet" problems with my Liftmaster garage door opener, iDevices switch, or Nest 24/7 cameras connected to my RBKE963 system. I have changed CTS/RTS Threshold to 2347 for 2.4Ghz.
I also disabled the "6 GHz Only Network" since I have no 6E-compatible devices and read in other posts that leaving this enabled has caused problems for some AXE system customers. You might also try making that settings change to see if it helps you any.
You are aware that 6Ghz is still broadcasting on the main WLAN radio right that separate from the 6Ghz SSID section?
FURRYe38 wrote:You are aware that 6Ghz is still broadcasting on the main WLAN radio right that separate from the 6Ghz SSID section?
I don't understand, can you explain in more detail? If I uncheck "Enable 6 GHz Only Network" isn't the 6 Ghz SSID disabled? What else is still running on 6 Ghz and what is it used for?
Thanks.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?For Apple devices, review this:
- MS_1234Guide
Thank you for your help! Here are the answers to your questions:
V6.0.3.85 is on the RBR and both RBS
Verizon FIOS ONT model number I-211M-L
About 3600 sq ft.
I am using a wired backhaul
The RBR is in the basement
The first floor RBS is about 15 feet horizontal distance plus about 5’ vertical distance from the basement RBR
The second floor RBS is about 20 feet horizontal distance plus about 10’ vertical distance from the first floor RBS
The house is typical residential construction. Sheetrock over wood studs.
2.4 GHz is auto
5 GHz is channel 48
6 GHz is channel 69
Yes. Occasionally I can see my neighbors WiFi. I have two neighbors, but rarely see the second neighbor’s signal. Seeing either neighbor’s WiFi signal depends upon where I am in my house, and it’s not a very good signal when I do see it
Does the front LED on the RBR turn on RED when this happens?
About 3600 sq ft.
For this size of home, you really only need the RBR and 1 RBS. Having too much signal in the home can be problematic.
The RBR is in the basement< Basements are not recommended placed for the RBR. Concrete and steel impacts wifi signal travel. RBR should be on main/1st level or a 2nd level.
Distances between the RBR and RBS to too close. 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using?
2.4 GHz is auto
5 GHz is channel 48
6 GHz is channel 69
Might try channel 1 and 40. 69 is Ok.
- DwayneWGuide
While I don’t have the 960 such as yourself. I do have the 850.
It has similar issues where it loses the internet, can’t get DHCP address.
At one time back in Oct when this happened it was after a firmware update that changed my rts/cts from 2347 to 64, once I change it back my Wi-Fi mesh was all happy once again.
Then last week happened…Same issue, some devices can connect via Wi-Fi, others can’t. I did not pay attention to what they may have in common.
But in trouble shooting by enabling my guest network, my iPhone was able to connect, get a dhcp address and life was good, but why do I need to do this?
So process of elimination lead me down the path of maybe it is another device conflicting with Orbi DHCP?
After unplugging one by one and testing theory, something was/is messing with Orbi Mesh DHCP and yet for reasons I can’t explain.
Remove the POWER from the Chamberlin myQ device. My guess is all your issues may be solved, after you reboot them so they may get back the DHCP reservation.
It has been a week, my network is happy and I do miss myQ, yesterday I plugged in myQ again and my devices started losing IP reservations again.
Hope this helps you and others.
