Nayef1
Apr 01, 2023Aspirant
Orbi Wi-Fi xfinity issue
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think something went wrong with my Wi-Fi specifically.
Should I do a hard a reset to resolve?
What Orbi model are you referring too?
Power cycle the system first OFF for 1 minute then back ON?
Try a reset as well.
- Nayef1AspirantRBR750.
I’ll try the power cycle for 1 minute. I tried 10 seconds before.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- Nayef1AspirantXfinity modem is XB7
4.6.14.3 firmware- FURRYe38Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
4.6.14.3 firmware
Nayef1 wrote:
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think something went wrong with my Wi-Fi specifically.Some additional detail would be helpful:
- Which Speed Test is showing the expected speed?
- A Speed Test report from the Orbi router web interface or the Orbi 'app'?
- A Speed Test run on a device wired to the Orbi? (Such as Ookla Speed Test)
- A Speed Test run on a device connected to Orbi over WiFi?
- If the Speed Test was a report from the Orbi, then it would be very helpful to use a web browser to connect to Ookla Speed Test and measure speed from both a wired and WiFi device. https://www.speedtest.net
- In what way are apps like Twitter and YouTube not working when connected over WiFi?
- What sort of devices is this happening with? (more than one?)
- Is it safe to assume that everything was 'normal' until just recently?
- Nayef1AspirantSpeedtest over wifi on iPhone and MacBook. Just started happening recently.
Either it opens tweets, videos and webpages very slowky or won’t load them at all.
Wired speeds and Wi-Fi speedtests are consistent.
- FarmerBob1Luminary
"Don't Do Speed Tests through a Web Browser."
Get the actual SpeedTest(.)net App and run it on all the Clients your are needing tests from. Through a browser is very inaccurate.
P.S.
Bridge Mode on the XB7 works with DOCSIS sources only, not Fiber. But the XB8 says it's 100% Bridgeable. Xfinity has a page on how to put it into Bridge Mode. With a lot of sales pitches.
