ddfdfd's avatar
ddfdfd
RBR750 Intermittant loss of signal
I have the RBR750 with 2 satellites.  I do have 20 or devices connected, including 2 laptops.  At times, the laptops, and laptops only, will lose the signal for a minute or two.  One of the laptops is even connected via ethernet.  None of the mobile devices/tablets have this issue.  What's also interesting is that as soon as I lose the signal, I can go to my tablet, log onto orbilogin.com, and the issue is immediately resolved on my laptop.  You might say this is a laptop issue, contact the laptop provider, but they are different laptop brands.
I already tried restarting the devices
I'm attached to a Comcast router in bridge mode.
I've updated firmware on both the router and laptop
Any help would be appreciated.
  • How are the two satellites connected to the router?
    (WiFi backhaul or 'wired' backhaul?)
    Is there any sort of Ethernet switch between the router and laptop?
    When all else has failed, the last resort is often to perform a Factory Reset on the router.  I absolutely hate doing this because it takes me almost two hours to type in all of the configuration settings I have made to reserve IP addresses, give names to each device and change the device type and model numbers, set up OpenVPN, DDNS, etc. etc.
    How much effort have you put into customizing the Orbi setup?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    ️What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    • ddfdfd's avatar
      ddfdfd
      Thanks FURRYe38 and CrimpOn,
      I think these are all of the answers to your questions:
      xfinity modem (in bridge mode model CGM4331COM
      Orbi router RBR750  Firmware - V4.6.14.3_2.3.12
      Good quality CAT6 cable
      distance is not an issue...wired is 20-25 ft, wireless is 10 ft
      Can't see where to check the channels
      noise from neighbors is not an issue, plus it's happening on the wired laptop
      Armor, Smart Parental Controls or Circle, Traffic Meter all disabled
      Windows 11 Home
      It always appears that it is connected to the network, no globe appears
      Some notice pops up on the screen? NO
      Is some process interrupted? (streaming? video conference?) NO
      Do web pages not load? they do not load, first I get the dns error, then no internet error
      • FURRYe38's avatar
        distance is not an issue...wired is 20-25 ft, wireless is 10 ft <Is this the distance between the RBR and RBS? If so, These distnaces are TOO close. 30 feet to start with in distance between the RBR and RBS. Regardless if the RBS are wireless or ethernet connected to the RBR.
        Can't see where to check the channels< On the RBRs web page under Basic/Wireless Settings
        Windows 11 Home <Be sure all wireless or ethernet adatper drivers are up to date from the adapter mfr chip set web site.
        It always appears that it is connected to the network, no globe appears< Globe?
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
        Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
        https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
        I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
        Press the back reset button for 15 seconds then release.
        https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
  • CrimpOn's avatar
    CrimpOn
    ddfdfd wrote:
    At times, the laptops, and laptops only, will lose the signal for a minute or two.  One of the laptops is even connected via Ethernet.
    It would be useful to know more about what "lose the signal" involves, especially.more detail about the wired laptop
    • Is this Windows? (10? 11?)
    • Does the network symbol in the lower right change from the picture of a computer screen to a funny 'globe' symbol?
    • Some notice pops up on the screen?
    • Is some process interrupted? (streaming? video conference?)
    • Do web pages not load?
