gustca01's avatar
gustca01
Speed Issues RBR850
I have a verizon modem that gives 1GB up and down. When I wire into it I can confirm the speeds. When my RBR850 is connected to it, I only get 100MB up and down. Not sure why any advice?
NOTE: On the port connections settings on the Verizon modem, it won't set to 1000 full duplex, just 100 full duplex. This only happens on the LAN connected to the RBR 850. Everything else does 1000 full duplex.
Is there a setting on the RBR850 that needs to be changed or something I'm not setting right?
  • CrimpOn's avatar
    CrimpOn
    Ethernet hardware (the actual physical equipment) has a mechanism to detect the highest speed that the link between two Ethernet devices will support:
    https://en.wikipedia.org/wiki/Autonegotiation
    If the CR1000A reports that the port connected to the Orbi RBR850 has negotiated 100Mbps, the most common reason is something about the cable path between CR1000A and RBR850 is "not right".  It could be
    • There is something wrong with the actual cable
    • There is something wrong with one of the RJ45 plugs on the ends of the cable.
    • There is something wrong with one of the RJ45 jacks (CR1000A, RBR850)
    The most common troubleshooting steps are:
    • Replace the Ethernet cable with another cable.
    • Physically examine the RJ45 jacks to see if one of those tiny gold wires is bent or misaligned.
    As FURRYe38​ pointed out, there is no obvious reason to keep the CR1000A unless:
    • Verizon is providing telephone service.
    • Verizon is providing television service.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    • gustca01's avatar
      gustca01
      The Firmware is: V7.2.7.15_5.1.16
      The Modem is a Verizon CR1000A with Firmware 3.6.0.2_BD
      The ONT is from Verizon. I can't find a model number on it. If it's helpful I can provide a serial number.
      I have the 1GB fiber plan from Verizon. The setup is Street -> ONT -> Verizon Modem -> RBR8750
      When I plug into the Modem or use the WiFi from it I get 800MB+ up/down speeds. Using the same cable, plugged into the 'Internet 2.5G/1G' port on the RBR850. I get 100MB up and down when plugged, on WIFI, and from the RBR850 speed test itself. Therefore I don't think its my cable, which is a CAT.6A.
      • FURRYe38's avatar
        What connection rate speed is seen on the RBRs web page ui on the Advanced tab and select Show Stats button for the WAN port? Should see 1000Mbps here.
        So the CR1000A is a router, not a modem: https://www.verizon.com/support/verizon-router-cr1000a/
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
        New: Static IP Address Configuration for AP Mode | NETGEAR Communities
        Give #2 a try.
        Something else to ask the ISP about, ask them if you can remove the CR1000A router and replace it with the Orbi RBR router.
