FURRYe38's avatar
Anyone using the AT&T BGW620-700 gateway?
Looking for any users that has an AT&T BGW620-700 gateway in their environment with Orbi BE system attached.
Looking for feedback and experiences.
Thank you.
  • This request is a year old. I was searching the 970 threads for other user experiences with the AT&T BGW620-700.I have one w/5G fiber service. I’ve had it for about 8 months with passthrough to a 970 and one satellite. All WiFi radios disabled on BGW and all security performed by AdvancedArmor on BGW and Armor on 970 disabled.  All this said to indicate there is a ~10% throughput reduction from BGW to 970 although not unusual with passthrough overhead on BGW.  I may switch to AP on the 970 but with 5gbs service, not noticeable.  BGW performance ~5300gbs up & down. 970 ~4700 down and ~5100 up. 970 firmware latest v12
  • FURRYe38's avatar
    Is IPv6 enabled on the RBR?
    What CAT# LAN cable are you using between the BGW and RBR? CAT6A STP is recommended.
    How are you speed testing? Ethernet PC for speed testing is recommended for best accuracy.
    Let us know if you can test AP mode on the RBR to compare results.
    • WRSORBI's avatar
      WRSORBI
      Luminary
      Cat 7, IPV6 disabled on BGW and 970. Rebooted both devices for this retest, BGW then 970. Testing using BGW internal Speedtest and 970 internal Speedtest. Not using PC since the NIC  is max 5G - Intel chip.  Passthrough follow. Will test AP and will post over weekend.
      Passthrough Results
      Gbps    - DOWN    UP       PING
      BGW        5385      5323      1.2
      970.          4763      5201.     1.2
      • WRSORBI's avatar
        WRSORBI
        Luminary
        Set 970 to AP.  Reset BGW to factory defaults (no passthrough). All Wife disabled on BGW and DCHPS set to Fixed.  Rebooted both.  Performance results no change on 970.  See below.
        Access Point Results
        Gbps    - DOWN    UP       PING
        BGW        5327      5331      1.2
        970           4604     5299     1.3
  • I recently upgraded to 5Gig Internet from AT&T, and the installer who came to do the upgrade installed this modem. I have been using it for about 2 months now with my RBE971 and one Orbi satellite. So far, I haven't noticed any issues.  Orbi router is working as the router with the BGW620-700 in Passthrough mode.
    • WRSORBI's avatar
      WRSORBI
      Luminary
      Would you have Speedtest results using the routers’ based Speedtest for comparison?  I also have ATT 5Gig service as well and started seeing the RBE971 drop from ~5200 gbps to ~4700 gbps download.  The BGW620-700 is constant ~5200 gbps down and up.
  • Set 970 to AP.  Reset BGW to factory defaults (no passthrough). All Wife disabled on BGW and DCHPS set to Fixed.  Rebooted both.  Performance results no change on 970.  See below.
    Gbps    - DOWN    UP       PING
    BGW        5327      5331      1.2
    970           4604     5299     1.3
    • FURRYe38's avatar
      Is Protection Enging enabled or disabled on the RBR?
      What is this CAT7 cable? UTP or STP?
      Try CAT6A or CAT8 STP?
      Brand and model# Ethernet NIC in PC?
      Are you speed testing with Ooklas speed test app on the Ethernet PC?
      • WRSORBI's avatar
        WRSORBI
        Luminary
        Protection Engine off. Cat 7 STP. REALTEK PCIe 5G.  Only testing with Ookla in the routers.
  • I neglected to mention what should have been the first point.  I did not have any degradation on the 970 running the V9 firmware.  The degradation began with V12.
