jeanluca's avatar
jeanluca
Follower
Apr 06, 2025
How to verify Wifi 7 from Orbi RBE971
I have a Netgear Orbi RBE973SB (router + 2 satellites), but I'm wondering how exactly Wi-Fi 7 works. From what I understand, it should use the 6 GHz band, but in my router’s configuration I only see settings for 2.4 GHz and 5 GHz. So how does this work exactly? Where is the 6 GHz band — or is it working differently than I expected?
Nothing indicates MLO or 320 MHz usage. I also haven’t come across any related settings in the configuration. The fact that I don’t have a Wi-Fi 7 device at the moment means I can’t really test Wi-Fi 7 properly.
Anyway. my goal is to see something that shows Wifi 7 is present, active and working!
  • What WiFi7 and MLO active looks like on my 970 RBR with Intel BE200 series cards install in two PCs:
  • plemans's avatar
    You'd need something that supports 320hz wide channels to see it. You might also need a different app. That same app on my phone with wifi 7 only shows 20hz wide channels in 6ghz but if I pull up a different one (acrylic) on my PC and laptop with wifi 7, it shows 320hz wide. And my link speed is indicative of that.
    • TOPS119's avatar
      TOPS119
      Virtuoso
      It doesn't show me wifi 7 either and I have a s25 ultra which is the latest model that shows wifi 7 wifi 6 comes up
  • Funny enough the 340 is depended on what region you live in they dont seem to allow ppl outside of the usa and Canada to select the 340 which is weird in my opinion
