piddyy
Oct 08, 2025Tutor
Orbi 770 – WiFi Drops Every Hour
At the beginning of the year, I posted in this forum about hourly interruptions with my ORBI770 mesh system. At the time, other users were experiencing similar problems, and I worked with Netgear Support to identify and solve the issue. Unfortunately, the past 8–9 months have been unsuccessful...
Recently, I have read less from others with the same problem. Perhaps the problem has been solved for others, or they have switched to a different vendor.
Unfortunately, the problem has not yet been solved for me, and I am still regularly writing to Netgear Support and uploading logs. Unfortunately, without a qualified answer or solution.
Over the past few days, I have tried a number of troubleshooting measures, such as:
- Adjusting NTP to a different NTP server
- Deactivating DHCP on ORBI and providing it on a Linux server
- Disabling private MAC addresses on all Apple devices
- and so on ...
Unfortunately, none of this has been successful and I still experience hourly interruptions. I have now provided ChatGPT with the information and uploaded the log files, and received the response in the pdf attached to this post. I am aware that ChatGPT is often wrong and often just writes nonsense (e.g. firmware version, which are not available). But maybe it points in the right direction, since Netgear Support doesn't feel responsible for simply analysing log files.
I also installed uptime-kuma on my computer and pinged various devices over the last few hours. I can only set the pings to every 20 seconds, so it doesn't catch all the hourly interruptions. However, you can see the pattern.
In the first three screenshots, I marked the interruptions at xx:03 / xx:04 in red.
In the last three screenshots, I ping the router and satellites (all wired). I find it interesting that the satellites respond faster than the router. But perhaps that is normal behaviour.
Am I alone, or do others still have the same problem?
Thanks.
Patrick
- donawaltMentor - Experienced User
piddyy Snailman12 MojoGene and others, I have a different Orbi - 970 series. Now there are two sides to this problem, the router/satellites, and the devices. Netgear has been working hard on improvements to the 970 FW, but they have been improving/updating the 770 and others as well.
For me, the issue was Apple devices, and later model ones - ones that support WiFi 6E or 7. I would get multiple disconnects a day per device.
I would like to suggest one thing to try, based on my experience; Apples notes on iOS/iPadOS 26.1 explained that WiFi disconnects had been addressed. So on October 29, I installed iOS/iPadOS 26.1 RC; I figured it was close enough to release quality I wouldn't be burned too badly lol. Then, when 26.1 was generally released on Nov 3, I upgraded to that. So for 9 days now I have been on a flavor of 26.1, and I have not had a SINGLE disconnect on either my iPadPro 2024 or my iPhone 16 Pro Max! My devices were clean from disconnects on both the RC and gen release versions.
This doesn't address issues with non-Apple devices, but it would be an interesting data point.
So - for you - if you have not already, can you consider upgrading your Apple devices to 26.1 and see how it works?
- Snailman12Aspirant
I’m having same issue. I see a possible WiFi drop solution related to ORBI 870 dealing with IPhone 16 Pro and IPad Pro 2024 on NETGEAR Community site. It starts with disabling IPv6 on router. Then go to router admin web page, advance tab, LAN setup…….. instructions a bit long here but your search should find it. I don’t have the time to work on my MacBook dropping WiFi until 48 hrs from now. Didn’t have problem until new router. I know new NETGEAR security doesn’t like older intel cores. They now say need Apple M1 chip. May be my problem on drops so will also uninstall new NETGEAR Armor VPN security. Feel your pain Patrick.
- Austin_Netgear1NETGEAR Expert
Hi piddyy ,
Could you please try disabling IPv6 and changing the Automatic Channel Selection to a fixed channel to see if that fixes the issue? We’d like to check if these settings are related to the problem.
Please refer to the following screenshots.
Austin
- piddyyTutor
Hi Austin,
Thank you for your message. I had already disabled IPv6 and changed the channel selection. Unfortunately, this did not help.
Hi piddy,
Thank you for the update and for testing those changes.
We appreciate your time and the detailed feedback.
Our team will continue to investigate this behavior further to identify the root cause.
We’ll provide you with an update as soon as more information becomes available.Austin
Have you checked the power levels, signal to noise ratios, error counts, and log file provided by your modem, to ensure that this isn’t coming from the outside network? What are they, and how do they compare to? What is recommended by your ISP? I am familiar with Comcast modem information, but it varies by ISP.
- piddyyTutor
Yes, I have checked everything and there are no faults on the modem. The problem also occurs with local traffic only.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Any Wifi Neighbors near by? If so, how many?
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.Has a factory reset and setup from scratch been performed since last FW update?
My 770 series is back online and is stable for me. Been solid on v.3. FW and prior. Had it online for around 20+ days back in July.
- piddyyTutor
- V10.5.20.3What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
- Sunrise ISP Switzerland Connect Box 3 Modem (DOCSIS 3.1)Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- Yes, tested also other cable, same issue.How many RBS are deployed?
- 220 square meter, around 2400 square ft
- 4 floors
- 1 router and 2 satellite with more than 30 feet distance between RBR / RBS
- Not sureDoes this happen with both wireless and wired devices?
- Only wirelessWhat channel configurations are currently set on the router?
- Different configs (48, Auto but also 40, 5)Any Wifi Neighbors near by? If so, how many?
- no
- All disabled except IPv6
- Can I disable this over Advanced - IPv6 - Internet Connection Type - Disabled?Has a factory reset and setup from scratch been performed since last FW update?
- Yes, nothing changed.- FURRYe38Guru - Experienced User
For that size of home, the RBR and just one RBS would be needed. Can you try with turning OFF one of the RBS for now?
Please see if the all RBS turned OFF if this still happens with the RBR alone.
Try channels 1 and 40 or 11 and 48.
Yes to disable IPv6.
How long have you had this system for?
