eric3312's avatar
Jan 19, 2026
Orbi 770 Satellites Randomly Disable All Radios and Drop Clients
I’m posting this to document a serious defect in the Orbi 770 series and to express growing frustration after months of dealing with it.
I have an Orbi 770 system (RBE770 satellites, firmware V10.5.20.3). One or both satellites will randomly stop broadcasting on all bands (2.4 / 5 / 6 GHz) while continuing to report a perfectly healthy status everywhere Netgear tells you to look.
From the router UI:
  • Satellites show “Good”
  • Backhaul (wired or wireless — tested both) remains connected
  • No warnings, alerts, or errors
From the Orbi mobile app:
  • Satellites show online and healthy
  • No indication of any issue
From the satellite’s own web UI (when you log in directly):
  • The page proudly states “Your WiFi Orbi Satellite connection is up and running”
  • However, ALL radios (2.4 / 5 / 6 GHz) are disabled
This is incredibly misleading. Yes, the satellite is powered on — but it is not functioning as a WiFi access point. The management interface claims everything is fine while the radios are effectively dead.
The only way to discover this is by:
  1. Noticing degraded WiFi performance, and
  2. Manually logging into the satellite’s local web UI to confirm the radios are disabled
There is no notification, no alert, and no exposed log entry that explains why this happens.
Impact
When this occurs:
  • Clients drop or cling to distant APs
  • Overall network performance degrades
  • The mesh effectively collapses silently
The only workaround is rebooting the affected satellite(s). This restores service temporarily, but the issue reoccurs — often once or twice per week. For a system in this price range, that is unacceptable.
Why “Interference” Is Not a Valid Answer
Even if this were RF-related (which I doubt), the platform provides no visibility and no control:
  • No RSSI / dBm metrics
  • No interference indicators
  • No spectrum analysis
  • No transmit power control
  • No actionable RF diagnostics
If satellites were “too close” (they aren’t, they're more than 40 feet away from each other), I still have no way to tune or mitigate overlap. The system simply disables itself and leaves the user guessing.
Additional Context
  • Firmware updates have not resolved this
  • Hardware has been RMA’d with no improvement
  • Wired vs wireless backhaul makes no difference
  • My neighbor’s Orbi 970 series exhibits the same behavior
  • All bands fail simultaneously, pointing to a firmware or radio state failure, not roaming behavior
Conclusion
This appears to be a fundamental firmware defect where the radio subsystem fails while every management interface (router UI, satellite UI, mobile app) continues to report “healthy” and “up and running.”
For a premium mesh product, silently disabling radios with no alert, no diagnostics, and no explanation is unacceptable.
If Netgear is aware of this issue, it needs to be acknowledged.
If logs exist, they need to be exposed.
If engineering is investigating, customers deserve transparency.
Right now, this product behaves like an expensive beta.
