eric3312
Jan 19, 2026Aspirant
Orbi 770 Satellites Randomly Disable All Radios and Drop Clients
I’m posting this to document a serious defect in the Orbi 770 series and to express growing frustration after months of dealing with it.
I have an Orbi 770 system (RBE770 satellites, firmware V10.5.20.3). One or both satellites will randomly stop broadcasting on all bands (2.4 / 5 / 6 GHz) while continuing to report a perfectly healthy status everywhere Netgear tells you to look.
From the router UI:
- Satellites show “Good”
- Backhaul (wired or wireless — tested both) remains connected
- No warnings, alerts, or errors
From the Orbi mobile app:
- Satellites show online and healthy
- No indication of any issue
From the satellite’s own web UI (when you log in directly):
- The page proudly states “Your WiFi Orbi Satellite connection is up and running”
- However, ALL radios (2.4 / 5 / 6 GHz) are disabled
This is incredibly misleading. Yes, the satellite is powered on — but it is not functioning as a WiFi access point. The management interface claims everything is fine while the radios are effectively dead.
The only way to discover this is by:
- Noticing degraded WiFi performance, and
- Manually logging into the satellite’s local web UI to confirm the radios are disabled
There is no notification, no alert, and no exposed log entry that explains why this happens.
Impact
When this occurs:
- Clients drop or cling to distant APs
- Overall network performance degrades
- The mesh effectively collapses silently
The only workaround is rebooting the affected satellite(s). This restores service temporarily, but the issue reoccurs — often once or twice per week. For a system in this price range, that is unacceptable.
Why “Interference” Is Not a Valid Answer
Even if this were RF-related (which I doubt), the platform provides no visibility and no control:
- No RSSI / dBm metrics
- No interference indicators
- No spectrum analysis
- No transmit power control
- No actionable RF diagnostics
If satellites were “too close” (they aren’t, they're more than 40 feet away from each other), I still have no way to tune or mitigate overlap. The system simply disables itself and leaves the user guessing.
Additional Context
- Firmware updates have not resolved this
- Hardware has been RMA’d with no improvement
- Wired vs wireless backhaul makes no difference
- My neighbor’s Orbi 970 series exhibits the same behavior
- All bands fail simultaneously, pointing to a firmware or radio state failure, not roaming behavior
Conclusion
This appears to be a fundamental firmware defect where the radio subsystem fails while every management interface (router UI, satellite UI, mobile app) continues to report “healthy” and “up and running.”
For a premium mesh product, silently disabling radios with no alert, no diagnostics, and no explanation is unacceptable.
If Netgear is aware of this issue, it needs to be acknowledged.
If logs exist, they need to be exposed.
If engineering is investigating, customers deserve transparency.
Right now, this product behaves like an expensive beta.
When you say you've had your 773 replaced multiple times and that your neighbor's 970 also exhibits the same behavior, it really piques my curiosity about your area. I've got an 773, an 873, and a 973 and haven't experienced any of this. When 1 device or package being bad is normal, 2 in a row is incredibly rare. But having 3 and then a neighbor with the same issue makes me think something in your area is broadcasting and causing issues/interference/blocking. Could be a random neighbor who picked up one of those cheap "wifi jammers' that used to be sold. Or something along those lines. Not sure but the odds of that many being bad is right up there with the lottery.
- eric3312Aspirant
So, I did have Eero 7 Max setup in my house and NEVER experienced this issue....I returned it and opted for Orbi because suprisingly the range on the Orbi 770 series is better than Eero's most expensive option...so, more bang for the buck.
I had the Eero max for probably...2 months ...never had the issue...satellites (or whatever Eero calls them) always had devices connected to them.
- eric3312Aspirant
Didn't return it - sold it to an old college buddy.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What devices do you have connected to the system in total?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Does this happen if these are all disabled on the RBR?
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
- eric3312Aspirant
Regarding the MFR/Model# of the ONT - can you give me a reason why this would matter? I'm not asking in a "smart-ass" way, I'm asking because it's hard to get to and does not seem relevant.
The LAN cable between the modem and router is the one that comes with the Orbi system. Presumably it's a good cable (I would hope).
Devices connected - usually around 22. Mixture of IoT devices (only a few), and laptops, phones, TV's, and gaming systems.
SQ Ft of my home is around 3,200.
Distance between router and satelite range between 35ish - to 45 feet.
I'm not sure if it the issue happens with the RBS turned off. I need connectivity in the various parts of my home, so I can't really test with the satellites off.
I don't know if the issue happens with those options disabled. I know I"ve turned Armor off and that hasn't resolved the issue. I can go ahead and try disabling the other ones though.
Any progress on this?
Asking about brand and model# of ONT or ISP Modem is very relevant. Helps us to establish issues that can be caused at this level. Just a question to help us better know what you have working with the Orbi system. Nothing nefarious meant by this questions. Most everyone gets asked this question.
For that size of home, the RBR and just one RBS would be needed. Having two RBS deployed could be causing problems. Try turning off the 2nd RBS.
Let us now if disabling all those features I suggested also helps.
- coolwifiLuminary
You could use wifiman app for iOS to test the radios.
- coolwifiLuminary
Looks like a defective product, I would return it or replace the buggy satellites under warranty.
- donawaltMentor - Experienced User
eric3312 do you have a Mac laptop you can walk around with? I use WiFi Explorer Lite app, from the Apple store, it's free and it works great. You will easily see all the info and any/all Orbis you have powered up (or not), including info on every band they are broadcasting:
- eric3312Aspirant
Ok, I did this. When the issue happens, the satelite is very clearly disabled as it reports in the web GUI of the satellite. It's basically a paper weight until I reboot it.
- eric3312Aspirant
I do. I’m happy to do that. But what exactly am I looking for? The web GUI of the satellites clearly state the radios are disabled, and my connection on devices close to those satellites is very weak, and I see them connected to the router which is far away. What should I look for that can lead to a resolution? Please excuse my ignorance.
eric3312 since we can't post images right now, below is my dropbox link to an image of my network in WiFi Explorer Lite. What you see is all the transmit bands on my 2 satellites and router. I didn't show the MAC address, but by looking at the MAC address you could could tell if each Orbi is truly transmitting on all the appropriate bands (2.4, 5,6 GHz), plus you should see the backhaul if your satellites use WiFi (mine are connected via Ethernet so they don't show here.)
Also, you'll see the highlighted bar, which confirms where your Mac is connected at that moment - Orbi and band. In addition, the dBm signal shows how string the signal is from each Orbi - that might provide a clue as you'll know which device should have the strongest signal. You probably need no worse than -67 to -70 dBm to have a decent signal, or greater (ie -30 dBm is fantastic signal).
This is a great independent assessment of exactly what's going on - could provide a big clue to where the issue is.
Hope this helps!
Does the Attached Devices display accurately report where devices are connected?
Does a WiFi Analyzer program, such as WiFi Info View (Windows) or one of the Analyzer apps for Android indicate that those BSIDs are no longer broadcasting?
- eric3312Aspirant
I am unsure what you mean. I will try to answer though.
The attached devices appear to be accurate, as the disabled satellite shows “No Devices Connected”, which makes sense.
I posted screenshots but maybe they got removed.
2nd, I believe you meant BSSID? If so, I have not tried an app yet to see if that’s the case. It definitely appears as though it’s the case.
no devices connected, radios show as disabled and gray in the satellite web UI, etc. I know, not definitive…if you have a good app to use for iOS, I’m happy to test.
