Saner
Jun 10, 2025Apprentice
Orbi 970 - Crash after Speedtest
Dear Commuinity,
In my RBE971 system with 1 satelllite with wireless backhaul, I have regular crashes /reboots of the RBE971 every 1-2 days.
While I was testing the behaviour , I also saw that I can easly crash the router via SpeedTest using router's web page or Orbi App.
Basically, you execute the sppeed test consecutively via the router's web page or Orbi application.
In my device, usually after 4-5 executions, RBE971 restarts (white linking led) or sometime it loose the network (magenta led)
My internet connection is 8Gbit and before the crash, SpeedTest usually shows around 7 - 8 Gbits of speed on both upload and download,as it should be.
I just want to ask if you also have same behaviour or I'm the only one... I suspect that the high speed is overheating the RBE971 and it crashes... I also put a fan on the top of the RBE971 and redone same tests, router charshed again but after 9-10 consecutive speedtests execution.
Any idea ? Can you also try the same test and update this topic with your results ?
PS : I already have a ticket with NG Support, they accepted the RMa for router only (not the kit), I'm waiting the delivery of the replacement unit in few weeks.
I received today the replacement router RBE971 and configured as AP with my 1 existing satellite.
NG sent only the router and I used my existing power adapter (with new design and increased amperage)
I have executed intensively Speedtest via WebUI and Orbi iOS app. Until now I couldn’t crash the new router. See below consecutive Speedtest via app
- SanerApprentice
I don't understand why/how but sometime my replies are deleted automatically Anyway, I try again.
In a previuos topis we discueed about the restarts and my config : I'm in France and using the modem/router Livebox 7 provided by ISP Orange France.
I'm in contact with NG Support since end of April and provided a lots of debug_logs related to my regular crashes.
Below you will see 2 samples from the file oopsdump :
==========================Kernel crash log 2025/5/21 23:05:25=====
Unable to handle kernel NULL pointer dereference at virtual address 00000d20
pgd = f6cf5fcb
Internal error: Oops: 817 [#1] PREEMPT SMP ARM
========== Timestamp: 2025-05-21 23:05:25 UTC ==========
Kernel panic - not syncing: Fatal exception in interrupt==========================Kernel crash log 2025/5/22 22:23:43=====
Unable to handle kernel paging request at virtual address fffffff8
Internal error: Oops: 837 [#1] PREEMPT SMP ARM
Kernel panic - not syncing: Fatal exception- FURRYe38Guru - Experienced User
What mode is the Livebox 7 modem with built in router working in? Modem only mode or router mode when the Orbi is in router mode?
If router mode, do you have the DMZ or IP pass thru enabled on the ISP router?
FYI:
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Possible that the data your coping and pasting in from the logs is causing a spam filter to trigger on those posts. Try using the Source Code tool bar option to post log code in to a post. Hopefully this will help that. All this is new forum SW and were all still getting used to it.
- SanerApprentice
I just want to ask to the different members of the Community if you can reproduce the same tests : consecutive Speedtests using the webUI of the router or Orbi app.
This test (consecutive Speedtests) is just 1 known way to crash my 971.
PS : I hope that the replacement unit will resolve all (at least most) of the crashes.
Certainly hope it does. Please post a comment when the replacement router arrives.
This issue with some 971 routers overheating has been discussed quite a bit on the forum. Obviously, if every 971 overheated, that would indicate a design flaw. The product would never have made it through testing and been released. The situation appears to be that some units are faulty* and there are only two solutions (1) replace the unit, or (2) install a fan to increase air flow through the router. Several users have reported placing an inexpensive fan on top of the router stops the reboot problem.
https://www.amazon.com/gp/product/B08ZSJFNMS
* There has been speculation as to what the fault might be. One possibility is that some units went through the assembly line and did not get the correct amount of thermal paste applied to major chips when assembled. Perhaps a "bad batch" of paste. Perhaps a person (or robot?) failed to apply enough paste. Who knows? The only way to validate that speculation would be to physically tear the unit apart. If Netgear has done that, it has never been made public. If a replacement router was not already "in route", it might be interesting to experiment with adding a fan. (I would do it just because the fans are so inexpensive and I LOVE this sort of stuff.)
- SanerApprentice
<1>[ 6024.605375] Unable to handle kernel NULL pointer dereference at virtual address 00000d20
<1>[ 6024.605379] pgd = f6cf5fcb
<1>[ 6024.605381] [00000d20] *pgd=a74a6835, *pte=00000000, *ppte=00000000
<0>[ 6024.605388] Internal error: Oops: 817 [#1] PREEMPT SMP ARM
<4>[ 6025.659482] ========== Timestamp: 2025-05-21 23:05:25 UTC ==========
<0>[ 6025.659483] Kernel panic - not syncing: Fatal exception in interrupt==========================Kernel crash log 2025/5/22 22:23:43=====
<1>[ 2509.184694] Unable to handle kernel paging request at virtual address fffffff8
<1>[ 2509.184698] pgd = b752dc37
<1>[ 2509.184700] [fffffff8] *pgd=bc1fd861, *pte=00000000, *ppte=00000000
<0>[ 2509.184706] Internal error: Oops: 837 [#1] PREEMPT SMP ARM
<0>[ 2509.882811] Kernel panic - not syncing: Fatal exception - SanerApprentice
One more update, as I have sent by RBE971 to NG for replacement (just router , not the full kit) I installed back my old 752 (1 router + 1 satellite with WiFi BH)
It works without any issue since more than a week..
I can't crash it with speedTest or any other way. As the 750 is limited to 1GBit of thernet, all network is limited to 1 Gbit but it works without any crash or restarts since +/- 10 days...!
- SanerApprentice
This is the latest public firmware 9.12.5.3 and the daily restarts happenned in all fw that I've used.
However I was never tried consecutive SpeedTests to crash the 971. With this Speed Test, i'm 100% sure that RBE will crash.
The ethernet cable between the RBE971 and modem is CAT6 and I tested also 2 other cables. Same problem.
Normally I use 971 in AP mode, but I tested both AP and Router mode: same RBE crashes always after consecutive speedtests.
The crash happpens during the Speedtest, after few successfull speedtests, WebUI become unresponsive and 971 reboots (white blinking led) or it became unresponsive with magenta led (don't answer to pings)
And this is reproducible in every try...
What is the brand and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Also lets turn OFF all logging on the RBRs web page as well under Advanced tab/Admin/Logging. Uncheck all boxes and apply the change.
After 5 consecutive speed test this morning on my RBR971 saw now issues. I then checked the system uptime under debug page and show stats for any changes there. Nothing. I'll try again later today after work.
Keep in touch with NG support and lets see if the RMA RBR sees same issue.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.I don't have 8Gb Up and Down here. 1Gb and 50Mbps. Just ran 5 speed tests using the RBRs web UI using MS-Edge. All successful. I had to leave so not sure if the crash happens soon after or later on. I didn't see any front LEDs as I left today. I'll check later on.
- donawaltMentor - Experienced User
OK, I just tested, as I have a 971 router and 2-970 satellites. I have Xfinity 2100/300 service.
Pre test:
router mem- 1079MB up: 4d 4h 14:15 cpu: 4.68%
5 speeds tests via router admin web page:
2333.16 - 358.23
2409.49 - 358.03
2268.65 - 356.48
2214.64 - 357.82
2105.62 - 350.49
router mem - 1076 up 4d 4h 20:13 cpu: 4.69%
5 speed tests via Orbi app on iPhone 16 Pro Max:
2263.83 - 356.02
2306.80 - 355.47
2372.85 - 353.93
2336.61 - 355.74
2348.69 - 357.28
router mem: 1074 up: 4d 4h 26:15 cpu: 4.70%
So no reboots for me. I also verified through the router port uptimes, that internet was not lost during the test:
So maybe this is an issue with the high speeds at least one user her has posted - 7-8 Gbps (that is if it's not a hardware failure). Not sure the speeds of the other user who reported the problem...
