ocnblue's avatar
ocnblue
Tutor
Oct 15, 2025
RBE771 Connection Constantly Dropping
I have an RBE771/RBE770 that I have had running for just under a year. My current setup I am using Ting and I get 2GB up/down.  They have a fiber modem which I run into the Orbi and I also have a NETGEAR 8-port 2.5G Multi-Gigabit Ethernet Plus Switch.
In the last month, I am getting 10-20 drops a day. I can't hit a website at all and everything comes to a grinding halt. Sometime the connection comes back after 3-5 minutes but lately I am just unplugging the Router to reboot it.
My firmware was current in the admin console but a Netgear search said the latest was V10.5.20.3 so I loaded that up about 4 days ago. No change on the drops at all.
I contacted Ting and they of course said everything was fine on their end. They show a solid connection and no errors.
Any suggestions on troubleshooting here? I will probably replace all cables this weekend for grins but this is nuts on a less than one year old Orbi Mesh system. My prior Orbi system was amazing for years but was limited to 1GB so I had to upgrade when Ting gave us 2GB. The logs I am looking at are basically worthless from the admin panel.  Just basic info and nothing isolating an error.
Appreciate any feedback!
  • CrimpOn's avatar
    CrimpOn
    It would help to have a detailed description of "drops".  i.e.
    • The WiFi signal disappears temporarily, or the WiFi signal does not disappear?
    • Both devices connected with Ethernet and devices connected via WiFi are affected?
    • When this happens every device connected to the system is affected the same way?
  • Good call out. Yeah every device loses connection whether they are ethernet or connected via WiFi.  It is like we hit a dead zone. I have seen speeds on Ookla go from 2100mbps d/l to 10mbps and then to zero.
  • The only thing I have tried is accessing the admin control panel which I can do from WiFi or ethernet. So LAN is good. Logs on the other hand I had setup to report everything but there is nothing being written to it when we lose connection.
  • FURRYe38's avatar
    Does the front LED on the RBR turn PINK or blink WHITE when this happens?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    How many RBS are deployed?
  • is it me or does this point to Ting?
    [Internet disconnected] Thursday, Oct 16,2025 12:15:18
    [DHCP IP: (192.168.1.51)] to MAC address 8C:E9:EE:20:D0:46, Thursday, Oct 16,2025 12:15:18
    [Admin login] from source 192.168.1.246, Thursday, Oct 16,2025 12:15:17
    [Internet disconnected] Thursday, Oct 16,2025 12:15:15
    [DHCP IP: (192.168.1.111)] to MAC address A0:D0:DC:F3:50:52, Thursday, Oct 16,2025 12:15:14
    [DHCP IP: (192.168.1.11)] to MAC address EE:FA:6C:03:BD:7B, Thursday, Oct 16,2025 12:15:11
    [DHCP IP: (192.168.1.58)] to MAC address 92:38:40:99:9D:9B, Thursday, Oct 16,2025 12:15:09
    [Internet disconnected] Thursday, Oct 16,2025 12:15:09
    [Time synchronized with NTP server] Thursday, Oct 16,2025 12:15:00
    [Internet disconnected] Thursday, Oct 16,2025 12:14:55
    • FURRYe38's avatar
      Possible...
  • Thanks all -
    I spoke to Ting - they can see the drops but they are saying it does not appear to be on their side. The connection has been solid. They are sending me an Eero System to see if it is the Netgear setup or on their side. If we continue to see drops, they will come out and look at it.
    On the RBR, I am not seeing any lights at all but will check it again when it happens.
    The ONT is a Calix 1100X
    My Cables are running STP from the ONT to the Router and Router to my switch. I ordered two new Cat6A Patch Cables(S/FTP) that will be here on Saturday. I will replace those for grins.
    Traffic Meter, Armor and Parental Controls are not on.
    • FURRYe38's avatar
      How about IPv6?
      Also are you using ISP detected DNS or custom DNS? If ISP, please try custom DNS like cloudfare or quad9.
      What is the model# of the switch connected behind the RBR?
      I presume you have tested the RBR with out the switch being connected?
  • I have ethernet connections directly into the Router and those also lose connections. The switch is mentioned in the initial post - NETGEAR 8-port 2.5G Multi-Gigabit Ethernet Plus Switch. IPv6 is disablled in the router. IPv6 is disabled in the router.
    • FURRYe38's avatar
      Something to try, put the NG switch in between the ONT and the RBR, only connect these two to the switch. Then see if the RBR still see's this issue.
      What is the model# of this switch? MS or GS something?
  • I enabled IPv6 - did not realize that was disabled.
    The switch is - MS308E-100NAS.
    I will give you suggestion a tr this weekend.
    • FURRYe38's avatar
      Ok, check with ISP to see if they support native IPv6. If they don't then you can keep IPv6 disabled. If they do, ask them which IPv6 configuration is needed.
    • FURRYe38's avatar
      Any progress on this?
  • The latest.....
    I spoke to Ting and they still claimed no issues. I changed my cables (although mine were already patch cables and were new) and still had disconnects. I called Ting back since they were going to send me an Eero router/satellite to test with and I had not received it. After that call, my issues stopped. I received the Eero 3 days later and I have not even unboxed it yet since I have not lost connection in well over a week.
    Based on the Orbi firmware being current and me not making any other changes, I am thinking the issue was on the Ting side and they finally resolved it. It would have been nice if they would have said yeah we see a problem and are working to fix it.
    Appreciate the help all!
    • FURRYe38's avatar
      Kinda figured it was an ISP issue. Sometimes it can be hard to help them recognize that. Glad it's all working now.
      Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
      Enjoy. 📡
