DarkSorrow
Mar 13, 2020Initiate
Internet completely dropping
For the past 2 days my RAX120 Router is completely dropping ALL internet activity from all connected devices. When I reboot the router it works for maybe 15-30 minutes then drops all connections again. I was running the .111 firmware and downgraded back to the .108 and the same things is happening with absolutely no connectivity. The router shows an active internet connection though in the settings.
Sort By
Same problem here. Have to reboot router several times a day, internet is sometimes shown as online, sometimes off line. Speedtest through Nighthalk app always works though
DarkSorrow wrote:
For the past 2 days my RAX120 Router is completely dropping ALL internet activity from all connected devices. When I reboot the router it works for maybe 15-30 minutes then drops all connections again. I was running the .111 firmware and downgraded back to the .108 and the same things is happening with absolutely no connectivity. The router shows an active internet connection though in the settings.- DarkSorrowInitiate
I think I managed to fix mine. I pushed in the reset button then manually reset the router. Once I was connected I restored my settings from a backup. It's been 2 days with no issues so far.
Having similar drop offs as well on a daily basis. I noticed these started to occur ever since I had the fiber optics service installed switching from my cable provider (Spectrum). The speed is excellent but these disconnects are far too many and I did not have this problem with Spectrum. I'm on the latest firmware: 1.0.9.88_10.2.88. What else can be the issue here?
Nothing else has changed on my network. I also noticed error messages on my 2.4Ghz devices stating I had too many devices on the wifi network. Never saw these errors on Spectrum either. I switched a few of the devices that supported 5g wifi and that seemed to help.
Thanks,
Rafael
- terryharrisonAspirantI'm having the same problems. Netgear sent me a new rax120 and it has the same problems. Tried 118 and 115 firmware.
For me a factory reset solved the issue. Pain in the butt but it worked.
Well. Spoke too soon. It lasted for about 48 hours, now it's back to dropping internet again. Guess it's time to open up a ticket with Netgear.
Thanks for your replies.
My router continues to disconnect from the ISP modem & dropping Wifi connections (both bands) and there is no rhyme or reason for this. Quite frustrating. Is there an internal test I can run on the router itself?
What I'm hearing is that even a total factory reset may not solve the problem. I did check the ISP vendor (modem & connection) and that is stable and no errors reported. This really started when I switched from Spectrum. Coincidence?
Am I going to have to buy a new router? Should I go with a Google device vs NetGear? I will do the research if I have to go down this path. The R7000 has worked well for the past few years. Thoughts?
I plan to reset it tomorrow morning when everyone is still sleeping then either restore the backup file or configure the devices one by one....
- TopologyVirtuoso
The (intriguing) observation by Jimpilot5 that “if you have an iPad or whatever connected via VPN it doesn't lose internet,” may suggest the presence of a DNS problem. In particular, note the similarity to the situation described in message #21 in RAX120 Router Random Disconnects. The solution appears to be a factory reset of the router, followed by manual entry of the settings (i.e., not importing a previously saved configuration file).
Topology wrote:The (intriguing) observation by Jimpilot5 that “if you have an iPad or whatever connected via VPN it doesn't lose internet,” may suggest the presence of a DNS problem. In particular, note the similarity to the situation described in message #21 in RAX120 Router Random Disconnects. The solution appears to be a factory reset of the router, followed by manual entry of the settings (i.e., not importing a previously saved configuration file).
I tried a factory reset a few days ago, it worked for a day or two then reverted. When I did I left everything in factory default when I did, didn't last long. I'm about two days into vpn holding solid connection, so somehow it has an effect. Wish Netgear would get on this.
- Over netgear and their garbage firmware issues I’m not saying they don’t make great products but they absolutely ruined my experience for life because of this I will never but another one I sent my router back and replaced it with a tp link and guess what 3 days of absolutely no problems and at a 1/3 of the price and same speeds and coverage sorry but not sorry netgear
- TheWengerAspirantSame issue here, fiber ISP and everything. Daily affair. Usually the worst possible timing too.
Nothing new to add, just came to add to the complaints.
