christer12's avatar
Jun 04, 2020
New Firmware Released RAX40 1.0.3.80 with WPA3
  • tsui's avatar
    tsui
    Jun 08, 2020
    New Features and Enhancements:
    Supports Smart Connect.
    Supports WPA3.
    Supports better device identification in the attached device list.
    Enhances the boot up time.
    Bug Fixes:
    Fixes the WiFi driver crash issue
  • Retired_Member's avatar
    Retired_Member
    The only thing I noticed immediately was the device icons and editing device names on the configuration. I was wondering the same, what is new in this new FW!
    • tsui's avatar
      tsui
      Tutor
      Supports WPA3.
      Bug Fixes:
      • I upgraded the firmware and the router crashes daliy now.. 1.0.3.80   It lookslike an issue with IOS  - WLAN access rejected: incorrect security.  But not sure... The new features are great but not worth the daily crash.  Very disappointed working from home.  I tried rolling back  the FW and restoring my settings but that did work.   I guess I will roll it back and restore factory settings and allow it to populate the access list..    Anyone else having issues with the new FW and it blocking / crashing?
    Retired_Member
    I am using Smart Connect and WPA2+WPA3 and it has been very stable since the release of the FW. The problem is FW rendered EAX20 extender unusable.
    If you are using WPA3 only, switch back to WPA2 and give it a try.
    • christer12's avatar
      christer12
      Star
      Yes, I use Smart Connect and WPA2+WPA3, my galaxy S8+ don't support WPA3. Just a few new devices support WPA3. I belive I just need to be patient with RAX40. I know what I signet up for. Wifi 6 isn't quite finished
        Retired_Member
        I jinxed myself, we had some dropped multiplayer connections on Nintendo Switch tonight. I feel like this router needs to be rebooted every so often.
  • It's really nice to see that the firmware is still broken and Netgear hasn't done a damn thing about it. Not even basic communication or a damn release note. This has defintely soured me on Netgear and their products, not that they care or like it will make any difference.
  • My wifi just stop broadcasting the signal after a few hours, it happened twice today. The lights are both on for 2.4g and 5g but I can't find the wifi on any of my devices
    • avf0000000000's avatar
      avf0000000000
      Tutor
      If you can get into your routers GUI.  You may find that you devices are being blocked.   Mine started with a couple then eventually all were blocked that were on the network.  Had to keep trying new devices until I could get in to unblock. I eventuly gave up did a factory reset.  I then rolled back to my old FW .   Has not crashed since..!   Hopfully Netgear is aware of the issue and is doing somthing about it..
      • ZacharyZSun's avatar
        ZacharyZSun
        Guide
        It might be! But the older version of 1.0.3 also has a lot of issues. I don’t have access to 1.0.2 firmware. Don’t know where to find it.
  • The firmware is not finalized. WIFI connection is interrupted periodically with devices (Smart Connect mode) Problem with connecting Samsung S20 phone. Communication with devices via WIFI may disappear and then the device cannot connect to the router. Only rebooting the router helps, but this is not normal for such a company.
    Most likely the firmware is very raw and will fix all problems soon.
