jweegar's avatar
jweegar
RAX45 log entry: [Internet disconnected]
Anyone know how to approach this issue?
Perhaps router needs to be replaced?
Internet disconnect happened last week and then again today.
Router is running latest Firmware: V1.0.17.142_2.0.100.
ISP (ATT - Fiber) reports no outages and status LEDs on ATT equipment look good (all green).
To fix internet disconnect issue, I simply turn off RAX45 router and then turn it back on again. But I'd like to stop this from happening altogether.
Oh yea, and when this problem happens, ATT equipment does not show RAX45 connected as it should. But after turning RAX45 off and then back on, ATT shows RAX45 connect and RAX45 shows a good internet connection.
Thanks for any help/pointers in getting this issue resolved.
  • FURRYe38's avatar
    Does the RAX WAN/Internet LED turn AMBER or RED when this happens?
    What is the model # of this ATT ONT that the RAX is connected too?
    Be sure your using a good quality LAN cable between the modem and router. CAT6  UTP is recommended.
    Is IPv6 enabled on the router?
    Using ISP detected DNS or custom DNS like Cloudfare or Quad9?
  • When internet disconnect happens:
    • RAX45 WAN/Internet LED is white (normal color, like it's connected to internet, but it's not)
    • The ATT ONT model is: ARRIS BGW210-700
    • Ethernet cable is in GOOD shape and connected properly.
    • IPv6 is ENABLED on the ATT ONT. IPv6 is DISABLED on the RAX45.
    • OpenDNS is being used (on the RAX45): 208.67.222.222 (primary) & 208.67.220.220 (secondary).
    • Since last firmware update, factory reset / setup from scratch has NOT been performed.
    Also, not sure if this matters but: the ATT ONT configures DHCP leases for 1 day & 0 hours/minutes/seconds. But on the RAX45 the "Connection Status" page shows a Lease Obtained as: 0 days, 0 hours, 10 Minutes.
  • Yes, the ATT ONT is in IP Pass-Through mode (option 2 above). And it's actually been working pretty well for several years now. It's just every once in awhile the RAX45 loses internet connectivity while the ATT ONT maintains internet connectivity. And the RAX45 is no longer listed in the ATT ONT's connected devices page. Power-cycling the RAX45 fixes the "no internet" problem and all is well until the next time. But recently (past couple of weeks) the issue happened twice (once last week and again then today). And I'm checking with the Netgear community to see if there's something I can do to prevent this issue from ever happening (unless the ATT ONT running on ATT Fiber really looses internet connectivity, which almost never happens). I'll read the suggested articles and contact ATT as suggested above. Thanks for your help.
