mshasib
Jun 26, 2021Aspirant
RAXE500 Link Aggregation Not Working
I purchased a Netgear RAXE500 recently and I'm on the latest firmware (V1.0.5.62_2.0.35).
I am unable to setup link aggregation on. I have tried both static and LACP mode using a Netgear and a TP-Link switch. But, none of them seem to be working. After turning on link aggregation, the Netgear router fails to provide a DHCP address to the connected switch and then the switch defaults back to its self-assigned IP address. I think there might some issue with loopback in the network when link aggregation is turned on.
Is anyone else using this router and been able to successfuly setup link aggregation?
- Razor512Prodigy
On your switch, did you enable LACP on the 2 ports that you have connected to the router? Both the router and the switch must have LACP enabledd otherwise you will run intl an unusable connection.
- mshasibAspirant
Yes, obviously. I setup LACP on both the router and the switch and then connected the cables on both ports.
- Christian_RNETGEAR Employee Retired
Hello mshasib,
Have you had a moment to reach out to our support team regarding this? Newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/contact.aspx
Christian
- joaosTutorI have LACP multi-gig (1 + 1) working on WAN side, connecting to an Arris modem, with no problem at all, but I had not tried the LAN side as it seems to be your case. Setting up the switch for link aggregation may be a little tricky though. If you have other hardware that supports LA (like NAS, for example), I would give it a try, just to discard the possibility that the problem might be with the router.
Latest firmware is V1.0.6.64, did you upgrade already?- Razor512Prodigy
With some managed switches, it can get tricky getting LACP working right, especially when they offer a ton of different methods and hashing types, where it could end up requiring some trial and error.
TP-Link tends to offer a bunch of options on their managed switches for hash algorithm, number of ports used, passive or active LACP, etc.
