dsg88's avatar
dsg88
Tutor
Nov 14, 2025
I can't find the parental Controls option in the Orbi app
Hi, I'm having the same issue with my RBR350 - Orbi AX1800 WiFi 6 Dual-band Mesh Router.
I can't find the parental Controls option in the Orbi app or on the router admin via web. I bought this system from Officeworks.
The Netgear website says all Orbi Mesh systems can use Parental Controls, however when I follow this guide (and the advice above) about logging in to the router to set up Parental Controls, I don't get that option. I've looked through every option on the admin dashboard and can't see it.
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
Parental Controls is not appearing under Advanced > Security.
  • CrimpOn's avatar
    CrimpOn
    dsg88 wrote:
    despite it being on the box when I bought it a year ago.
    This might be a key factor.  When a product clearly does not meet claims printed on the box, I would think the consumer has a valid reason to return it for a full refund.  In this case, however, waiting a year to notice the discrepancy creates a bit of a quandary.
    • StephenB's avatar
      As usual, consumer rights depend on the laws in the country of purchase.  Since this is an international forum, it generally doesn't lead to a fruitful conversation here.
      That doesn't mean dsg88​ and Peter-R​ can't pursue a return, just that the options for resolution (if any) will depend on the country (and might be not the same in Australia and the Netherlands).
  • Thanks CrimpOn.
    It doesn't show up on my app either. I have a feeling my model (RBR350) can't have Parental Controls. I have been researching all day, and I have to say the information from Netgear is totally inconsistent!
    e.g. here is a list of routers that support parental controls
    https://kb.netgear.com/000064166/Which-products-support-NETGEAR-Smart-Parental-Controls
    and here's another (much shorter list)
    https://www.netgear.com/ca-en/home/services/smart-parental-controls/
    and this one (not on the lists above) advertises it on the box, but is not on the lists above :(
    I can only assume Orbi is dropping Parental Controls at some point after launching a product?
  • CrimpOn's avatar
    CrimpOn
    Smart Parental Controls is a feature of the Orbi 'app', not the web interface.  This is a screen shot of the Android Orbi app, version 2.49.0.5034:
    Which version of the app do you have (Apple or Android?)
