maminova
Jul 31, 2023Aspirant
GS316EP programmation horaire POE
bonjour, la programmation horaire des ports POE ne fonctionne pas, il ne s'éteigne pas. D'avance merci
- Aug 01, 2023
Some images of the SNTP and DST configurations - hope this does help. Have only a similar switch at hand, slightly different UI however. Key is to configure unicast servers (not broadcast).
Sorry for replying in English. Fluent on reading however, old Swiss here, but not so easy to write 8-)
schumaku
Jul 31, 2023Guru - Experienced User
SNTP correctly configured, correct data and time set on the switch?
What PoE schedule have you set in place? On, Off, ... @ ?
On a side note, I'll request moving this thread to the Plus And Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management
maminova
Aug 01, 2023Aspirant
Bonjour,
Date et heure du Switch correctement configuré, pas de serveur sntp configuré mais
local.
programmation horaire POE sur port 1 on:7h30/ off:23H
Cordialement.
- schumakuAug 01, 2023Guru - Experienced User
local.
Strongly suggest to configure the SNTP server. There is no local clock for backing the time....
- maminovaAug 01, 2023Aspirant
Pouvez vous me donner un exemple de configuration sntp pour mon cas.Je ne suis pas un spécialiste dans ce domaine.
Merci
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
