daniel4ball
Jul 13, 2017Follower
C3000 modem/router --> bridge connecting an AC1750
Will I loose the features of my original AC1750 if I buy my own C3000 modem/router and use that as 1st and bridge the AC1750 behind it? My home isn't tiny so I would like to use both to extend my range across different areas of the house.
1 Reply
- dpswindAspirant
Just my two cents... I have used the AC1750 as my edge device with WiFi and used another brand router to extend my WiFi, and there is a penalty... the other brand was only 2.4Ghz, and I was kneecapped whenever I connected wireless on that network. I am not familiar with the specs of the C3000, but compare and if functionally similar you should not have a problem. I removed the other wifi, and have not had a problem with running the C6300 by itself. Good luck !
