beni0208
May 21, 2016Initiate
C6250 conflicting country codes
I am using a NetGear AC1600 (C6250) cable modem router and a NetGear AC750 (EX3700) wifi range extender in DENMARK. Also use various devices - AppleMacbook, Huawei Android Phone, Samsung Android ...
beni0208
Sep 13, 2016Initiate
Hey DarrenM,
My wifi is set to channel 44 on 5ghz and to channel 4 on 2.4ghz. The extender's channels are set for automatic and i cannot change on that, no idea why, but the options are inactive for interactions.
Please help :) the same situation is still existent.
DarrenM
Sep 15, 2016Sr. NETGEAR Moderator
Hello beni0208
The extenders channels follow the channels that the main router is set to so you would have to change it on the router.
DarrenM
