jb58's avatar
jb58
C6300 wireless stopped working after changing Router Mode = No
I have a AC1750 WiFi Cable Modem Router(Model C6300), and followed the Quick Start guide to setup the unit. The unit was activated successfully with TWC, after registering on the NetGear website I found the User Manual. The first thing the manual says to do is to 'From the Basic Home page, Select ADVANCED > Administration > Router Mode and select the No radio button'. When the Apply button is pressed the unit reboots but the WiFi does not turn back on and I have no way to access the setup page of the unit. How do I overcome this? To access the unit I had to use the 'Reset' button on the rear. The unit is back up and running but with the Router Mode = Yes.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jb58
    You may have to use 192.168.100.1 when you set that to no if not try 192.168.0.1.
    DarrenM
    • jb58's avatar
      jb58
      Thank you for the response Darren. I don't think the IP address is the problem though, when I clicked 'Apply' the router reset but neither of the Wifi led's were illuminated and there was no Wifi available for me to log on to the router.
      • Setting Router Mode = No puts it into bridge mode.  I would expect Wi-Fi to stop working.
