ezicefield
Jan 27, 2016Follower
C7000-100NAS randomly drops internet connection
Hello,
My C7000-100NAS modem seems to randomly drop it's Comcast connection. This happen on 2.4 ghz, 5 ghz, and wired connections. There is no pattern, however the dropped connection usually lasts 2-5 minutes. When this happens, using the Netgear Genie is useless, it just stalls when trying to connect. Connecting to the IP of the modem works fine to reach the admin page. When the connection drops, the cable connection report on the C7000-100NAS shows the connection is good, 20x4 bonding. Other times, it reports the connection is offline.
I've been on the phone with Comcast, and they are not seeing anything wrong with the line, and no firmware updates are needed or available.
I see there are many reports of this same behavior with this model. The Amazon page is littered with them. I wish I had seen these reports before buying this pricey peice of equipment. I am hoping Netgear has a resolution. Of course the compimentary support period ended like 10 days ago, which is another source of frustration with this product.
Any help would be appreciated. Thanks.
- HKahlerTutor
It's interesting that Netgear has allowed this to continue on for two years. Same problem here, all the following messages repeat every 30-45 minutes. Talked w/ my ISP (spectrum/twc) and they came out tested the line into the house and from the wall to the router--all good. Troubleshot w/ netgear techs, reduce MTU size, factory restore, problem doesn't stop. Tech recommended replacing it if the factory restore didn't work. Fortunately I bought from Amazon and I'm awaiting the replacement tomorrow (but this five page message train doesn't give me much hope it will work, so if it doesn't I'll just go w/ a refund):
2018-8-14, 21:09:10 Warning (5) MDD message timeout;CM-MAC=78:d2:94:8c:c5:90;CMTS-MAC=00:01:5c:69:22:73;CM-QOS=1.1;CM-VER=3.0; 2018-8-14, 21:09:10 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=78:d2:94:8c:c5:90;CMTS-MAC=00:01:5c:69:22:73;CM-QOS=1.1;CM-VER=3.0; 2018-8-14, 21:09:42 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=78:d2:94:8c:c5:90;CMTS-MAC=00:01:5c:69:22:73;CM-QOS=1.1;CM-VER=3.0; 2018-8-14, 21:09:57 Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 2018-8-14, 21:10:12 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=78:d2:94:8c:c5:90;CMTS-MAC=00:01:5c:69:22:73;CM-QOS=1.1;CM-VER=3.0; 2018-8-14, 21:10:12 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=78:d2:94:8c:c5:90;CMTS-MAC=00:01:5c:69:22:73;CM-QOS=1.1;CM-VER=3.0;
- TbalfanyAspirantThe fix for us was change the 2.4 to channel 6 and 5ghz to channel 157 on the wireless tab of the Netgear genie ( or router login page ).
- CCutterTutorThank you for your reply! I turned it into a modem only and bought the google Wifi router, very very happy with google, not a single issue! Good luck with your solution!
Glad that worked for you, but that is not the orginal issue. The orginal issue was dropping the connection with the ISP not the client devices connected to the router. Channel switching can help device connection connection issues in areas with a concentration of wireless routers all broadcasting, but that feature is unrealted to the routers connnection with comcast, centurylink, timewarner or whomever the ISP is.
- junfitzGuideHello,
Switching channels only works temporarily. That channel will eventually get full again within 1 - 3 days. If you don't mind having to do it often, that's a good solution. But if you want a permanent fix, turn your Netgear into Modem only and use the Google Wifi as your router. I believe it's been almost a year or longer with no more problems here. Good luck!
