alzibiades's avatar
alzibiades
Can’t access my WD My Book World network hard drive via my Netgear D6300 Router
Bought the new C6300 but network drive is no longer visible. I plugged it into the ethernet connection on back of modem/router but my computerWD software can not see it. I have not been able to figure out how to gain access. Network drive worked fine with Comcast modem/router before I changed. The ethernet green light is lit on front of modem/router showing that it connected. Any suggestions?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello alzibiades
    Are you able to ping the drive at all or is it showing up to the attached devices?
    DarrenM
    • alzibiades's avatar
      alzibiades
      It is showing up on the modem as connected but I can't access it from any electronic device. I have disabled my firewalls on each device thinking that was the problem but it still will not locate it. At this point I am at a loss on what to do. I have reset the settings on the modem thinking that it had some internal firewall or something and I still get the same result.
      • DarrenM's avatar
        DarrenM
        Hello Alzibiades
        Is there any port forwarding that the Hard drive needs?
        DarrenM
