patricia2626
Dec 21, 2016Aspirant
cm1000 modem 3.1
has any one test it from xfnity 1000 plan and tv cable has any one heard anything of it or review and will this works for tv cable and is there any erros or devites i need to look out for as my servi...
- Dec 23, 2016
Hello patricia2626
This is a cable modem only so it will only handle cable internet.
DarrenM
DarrenM
Dec 23, 2016Sr. NETGEAR Moderator
Hello patricia2626
DarrenM
Trikein
Dec 26, 2016Luminary
FYI to OP and Moderator. The CM1000 is not compatible in some areas depending on the infractrure(CMTS) in the area. As per user telcodad, who appears to have engineering background:
"The CM1000 was certified on the older CBR8 code. Cisco later issued a code update to support their new D3.1 line cards, so MSOs can't rollback to the old code now without removing those D3.1 line cards."
See full thread here.
