Chazz
Oct 07, 2015Tutor
CM500 status log for high db power on upstream
2015-10-3, 10:42:00 | Critical (3) | Resetting the cable modem due to docsDevResetNow | |||||||||||||||||||||||
| 1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:27 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:28 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC= | |||||||||||||||||||||||
| 1970-1-1, 00:00:20 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC= | |||||||||||||||||||||||
| 1970-1-1, 00:00:30 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:30 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM--MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:33 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; | |||||||||||||||||||||||
| 1970-1-1, 00:00:40 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
Upstream power is still too hot (ideally should be dropped by 6 dB if possible). I think someone at the ISP side need to reduce one of the attenuators in the upstream direction.
are you facing any dropouts?
- vkdeltaNETGEAR Employee Retired
Looks like your ISP (most probably comcast) has enabled something called "Extended Upstream Power" on your account (which is good thing).
Knowing that your Cable modem literally need to transmit at such high power, it is probably because you have too many splitters in your home or you have too much attenuation in your RF line coming into your home
- ChazzTutorThanks for reply.
I have one splitter in a bedroom with a power supply feeding it. I call it a wall wart. There may be one more splitter at the box outside.
Would it be worth eliminating the one outside and I believe I don't need it anyway. To get a quicker or smoother connection?- vkdeltaNETGEAR Employee Retired
yeah, better to eliminate spliters you really dont need.
are you mixing Satellite (direcTV, Dish, etc) and Cable connections in your home? I guess now. Most people who have outside splitter, they have Internet from Cable company and TV service from satellite guy. OR sometimes it is just something old owner put that in.
- ChazzTutor
No, comcast for tv and internet. im getting a diagram together so ill know how the wire runs and what splitters are there. I know its a littlke jacked up cause they were in a hurry. The installers didnt know ive been a low voltage tech for 20+ years lmao. Will get back to you on counts.
- ChazzTutorNo been up and running fine getting 90 down and 12 up. I have eliminated coax or splitters in house. Has to be on pole, am I correct?
- ChazzTutorThanks so much
