MayBTime2Change
Jun 06, 2017Tutor
Comcast customers: will Firmware V3.01.14 fix my N450 (CG3000Dv2) connectivity issues?
For the past half a year, my N450 (CG3000Dv2) cabel modem router has been completely unreliable. It regularly drops connection. Sometimes restarting helps, sometimes it doesn't. I've rebooted the box a couple times, and that helps for maybe a day, sometimes less. This connectivity issue seems to be a common complaint for N450, and also seems to be tied to the V3.01.06 firmware (makes sense to me, based on when my problems started). I see that V3.01.14 has been pushed by Comcast to its customers. Any Comcast N450 customers on here who had connectivity issues with V3.01.06? And if so, did those problems go away with V3.01.14? I have Spectrum, which is still using V3.01.06.
It's really frustrating to be experiencing this problem, especially since I had suffered through the same issue over a year ago. That time, the probably spontaneously resolved, presumably when the Firmware was updated. I think it happened around the same time as the Time Warner Cable merger with Charter, and this time the problem seems to correspond with the mergers with Spectrum.
- DarrenMSr. NETGEAR Moderator
Hello MayBTime2Change
Are you just having wifi connection issues or is the modem dropping wired and wireless connections?
DarrenM
DarrenM wrote:Hello MayBTime2Change
DarrenM
Great question - it's dropping both. We use wireless for most of our devices, but our Apple TV is hooked up to the modem directly and also gets dropped.
Can you post the modems logs when these drops are happening.
DarrenM
