Juventus_nz
Mar 04, 2017Follower
DoS Attacks in the logs
Hey guys
I have been getting disconnected from the internet at different times over the past week. At first i thought it might have been an ISP issue, spoke to them and multiple line checks revealed no issues....during the drop outs i wasnt able to ping the router (Nighthawk D7000) or any devices on my home network, i have checked the logs and it contained multiple DoS attack entries as below
DoS attack: ACK Scan] from source: 51.254.7.95:80 Sunday, March 05,2017 08:43:45
[DoS attack: ACK Scan] from source: 51.254.7.95:80 Sunday, March 05,2017 08:42:30
[DoS attack: ACK Scan] from source: 51.254.7.95:80 Sunday, March 05,2017 08:41:14
[DoS attack: ACK Scan] from source: 51.254.7.95:80 Sunday, March 05,2017 08:39:59
I went ahead and disabled remote management and turned off upnp etc....propblem still persisted. I have changed the router to a new one (same model) and Dos attacks continued. With our ISP i get a new public IP address everytime i restart my router so there is really mo chance of this being a Real DoS attack as my IP changed on a daily basis (atleast over the past week)
Done a scan on all the home laptops for any malware nothing!!
I am stuck and not sure what to do? Is this a fault with the firmware / netgear equipments?
Any help is greatly appreciated
Cheers
Cheers
- DarrenMSr. NETGEAR Moderator
Hello MrCarrotlll
The power level look fine what about the logs are you seeing any type of timeouts?
DarrenM
Hello Mrcarrotlll
Are you able to post your logs and levels of the modem it could give a better Idea of why the disconnects are happening.
DarrenM
- MrCarrotIIIAspirant
<tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR 1 Locked QAM256 102 801000000 Hz 2.1 dBmV 38.7 dB 2 Locked QAM256 101 795000000 Hz 2.0 dBmV 38.6 dB 3 Locked QAM256 103 807000000 Hz 2.1 dBmV 39.0 dB 4 Locked QAM256 104 813000000 Hz 2.0 dBmV 39.0 dB 5 Locked QAM256 109 843000000 Hz 1.1 dBmV 38.6 dB 6 Locked QAM256 110 849000000 Hz 0.7 dBmV 38.6 dB 7 Locked QAM256 111 855000000 Hz 0.2 dBmV 38.0 dB 8 Locked QAM256 112 861000000 Hz -0.1 dBmV 37.8 dB <tabindex=-1>Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 21984000 Hz 44.8 dBmV 2 Locked TDMA and ATDMA 1 2560 Ksym/sec 17154000 Hz 44.0 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 28414000 Hz 45.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 34844000 Hz 45.5 dBmV
- MrCarrotIIIAspirantHey DarrenM
Do you have any ideas for me and the OP? Thanks!- xnavStar
I gave up on Netgear and bought a Motorola, and have not seen the problem in 3 days now.
Hello KClaeys
All the levels look good from what you posted but those could change when you are losing service maybe its a line issue outside it happens alot when neighbors get cable hooked up a tech could mess someone else connection up I guess you will find out when the tech comes.
DarrenM
- KClaeysAspirant
Hi Darren,
The cable company came out and ran a new line from the house to the pole, put a new box on the house, we moved the modem, used new cables on everything and I am still having issues. Now I am getting T3 and T4 timesouts. One day the internet was dropping literally every 10 minutes. Of course, Cox tells me it is on my end and they are getting great signals. Interestingly enough, when I contacted that university about not pinging my internet, I haven't had one DoS attack. Here is the log from today when trouble started (again). I am considering getting a modem from Cox and if I still have the same problems with one of THEIR modems, then I guess it is on them.
Time Priority Description Mar 25 2017 20:31:39 Notice (6) TLV-11 - unrecognized OID Mar 25 2017 20:31:39 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Mar 25 2017 14:57:58 Notice (6) TLV-11 - unrecognized OID Mar 25 2017 14:57:57 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Mar 25 2017 14:52:58 Notice (6) TLV-11 - unrecognized OID Mar 25 2017 14:52:57 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Mar 25 2017 14:50:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:50:15 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:49:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:49:15 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:48:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:48:15 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:47:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:47:15 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:46:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:46:15 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:45:45 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:45:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:44:46 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:44:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:43:46 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:43:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:42:46 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:42:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:41:46 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:41:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:40:46 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:40:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:39:47 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:39:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:38:47 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted Mar 25 2017 14:38:47 Critical (3) Ranging Request Retries exhausted Mar 25 2017 14:38:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:37:47 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:37:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:36:47 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:36:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:35:47 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:35:18 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out Mar 25 2017 14:34:48 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:34:48 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out Mar 25 2017 14:34:48 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out - DarrenMSr. NETGEAR Moderator
Hello KClaeys
It could be a bigger issue away from your homes lines but yea you may want to test another modem to be sure if its on there end or not but typically those T3 and T4 timeouts are.
DarrenM
Hello KClaeys
I checked and here is where your Dos attacks are coming from
https://ant.isi.edu/datasets/about.html
also are you seeing any type of timeouts in your logs?
DarrenM- DarrenMSr. NETGEAR Moderator
Can you post the power levels on the Cable connection page check to see if anything is off. You may also want to check if you have a cable splitter connected to the modem they can cause some issues try plugging straight to the wall. Also have you had your ISP come out and check your lines?
DarrenM
- KClaeysAspirant
I don't use a splitter, so I know that itsn't the problem. I'm going to have the cable company come out, even though they all tell me it's on my end. Here are the logs for the power. Please let me know if you see anything odd.
<tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 121 813000000 Hz -7.7 dBmV 37.6 dB 0 0 2 Locked QAM 256 122 819000000 Hz -7.7 dBmV 37.6 dB 17 0 3 Locked QAM 256 123 825000000 Hz -7.2 dBmV 37.6 dB 0 0 4 Locked QAM 256 124 831000000 Hz -7.5 dBmV 37.6 dB 0 0 5 Locked QAM 256 125 837000000 Hz -7.7 dBmV 37.6 dB 0 0 6 Locked QAM 256 126 843000000 Hz -8.2 dBmV 38.6 dB 0 0 7 Locked QAM 256 127 849000000 Hz -8.2 dBmV 37.6 dB 0 0 8 Locked QAM 256 128 855000000 Hz -8.7 dBmV 37.6 dB 0 0 9 Locked QAM 256 137 909000000 Hz -9.7 dBmV 37.3 dB 3424 48193 10 Locked QAM 256 138 915000000 Hz -10.2 dBmV 34.3 dB 4098 68314 11 Locked QAM 256 139 921000000 Hz -10.5 dBmV 37.6 dB 2086 41253 12 Locked QAM 256 140 927000000 Hz -10.7 dBmV 36.6 dB 284 7327 13 Locked QAM 256 141 933000000 Hz -11.4 dBmV 36.3 dB 0 0 14 Locked QAM 256 142 939000000 Hz -11.7 dBmV 36.3 dB 0 0 15 Locked QAM 256 143 945000000 Hz -12.5 dBmV 36.3 dB 0 0 16 Locked QAM 256 144 951000000 Hz -13.3 dBmV 35.7 dB 0 0 <tabindex=-1>Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 2560 Ksym/sec 21600000 Hz 41.3 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 26500000 Hz 41.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 33000000 Hz 42.8 dBmV 4 Locked ATDMA 4 2560 Ksym/sec 37900000 Hz 42.8 dBmV
- KClaeysAspirant
Hi Darren,
Thanks for the info. I am planning on writing them a scathing letter to get them to stop. I don't think it is all them though. Anyway, I checked the logs and this is the first thing I saw:
DoS attack] AIF:Dropped INPUT packet: PROTO:TCP SPT:9090 DPT:22 1 Tuesday, 07 Mar 2017 11:17:48 68.102.73.127 221.229.160.210 [DoS attack] ICMP Flood from 206.117.25.90 1 Tuesday, 07 Mar 2017 09:49:06 68.102.73.127 206.117.25.90 Any ideas on what to do? I am seriously upset because of the dropped internet. This is really killing my paycheck.
- KClaeysAspirant
I am having the same issue with these attacks. I am at my wit's end with what to do. I work from home and cannot afford to keep having these dropped internet issues. The attacks are happening daily, multiple times a day. Is there anything that can help? I am so freaking aggravated, it isn't funny. These are but just a few of the attacks. My provider is Cox Communications.
DoS attack] ICMP Flood from 206.117.25.90 1 Monday, 06 Mar 2017 09:48:06 68.102.73.127 206.117.25.90 [DoS attack] ICMP Flood from 129.82.138.44 1 Monday, 06 Mar 2017 07:56:30 68.102.73.127 129.82.138.44 [DoS attack] ICMP Flood from 212.1.84.56 1 Monday, 06 Mar 2017 07:24:23 68.102.73.127 212.1.84.56 [DoS attack] ICMP Flood from 195.251.255.69 1 Monday, 06 Mar 2017 07:00:58 68.102.73.127 195.251.255.69 [DoS attack] AIF:Dropped INPUT packet: PROTO:TCP SPT:9090 DPT:22 1 Monday, 06 Mar 2017 05:55:01 68.102.73.127 221.229.160.210 [DoS attack] ICMP Flood from 203.178.148.19 1 Monday, 06 Mar 2017 05:06:49 68.102.73.127 203.178.148.19 [DoS attack] ICMP Flood from 187.54.115.129 1 Monday, 06 Mar 2017 05:00:33 68.102.73.127 187.54.115.129 [DoS attack] ICMP Flood from 185.94.111.1 1 Monday, 06 Mar 2017 04:43:12 68.102.73.127 185.94.111.1 [DHCP IP: (192.168.0.104)] to MAC address 00:0b:82:67:70:9d 1 Monday, 06 Mar 2017 04:32:38 0.0.0.0 0.0.0.0 [DoS attack] ICMP Flood from 206.117.25.90 1 Monday, 06 Mar 2017 01:33:03 68.102.73.127 206.117.25.90 [DoS attack] AIF:Dropped INPUT packet: PROTO:TCP SPT:56766 DPT:23 1 Monday, 06 Mar 2017 00:13:49 68.102.73.127 5.232.188.59 [DoS attack] ICMP Flood from 129.82.138.44 1 Sunday, 05 Mar 2017 23:42:13 68.102.73.127 129.82.138.44 [DoS attack] ICMP Flood from 195.251.255.69 1 Sunday, 05 Mar 2017 23:08:04 68.102.73.127 195.251.255.69 [DoS attack] AIF:Dropped INPUT packet: PROTO:TCP SPT:9090 DPT:22 1 Sunday, 05 Mar 2017 22:34:18 68.102.73.127 221.229.160.210 - xnavStar
Im also having the same problems as you. Its constant, Ive been trying to find a way to block this IP address but with no luck. I lose connection each time this happens.
Teardrop or derivative] 1 Sun Mar 05 17:56:37 2017 121.13.197.171:0 73.0.209.0:0 [Illegal Fragments] 1 Sun Mar 05 17:56:37 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 3 Sun Mar 05 17:56:37 2017 121.13.197.171:0 73.0.209.0:0 [Illegal Fragments] 1 Sun Mar 05 17:56:40 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 1 Sun Mar 05 17:56:40 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 2 Sun Mar 05 17:56:42 2017 121.13.197.171:0 73.0.209.0:0 [Illegal Fragments] 2 Sun Mar 05 17:56:46 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 1 Sun Mar 05 17:56:48 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 1 Sun Mar 05 17:56:50 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 1 Sun Mar 05 17:56:55 2017 209.251.223.129:0 73.0.209.0:0 [Illegal Fragments] 2 Sun Mar 05 17:56:55 2017 209.251.223.129:0 73.0.209.0:0 [Teardrop or derivative] 4 Sun Mar 05 17:57:59 2017 209.251.223.129:0 73.0.209.0:0 [Ping Of Death] 1 Sun Mar 05 18:01:04 2017 209.251.223.129:0 73.0.209.0:0 [Teardrop or derivative] 1 Sun Mar 05 18:02:24 2017 121.13.197.171:0 73.0.209.0:0 [Illegal Fragments] 1 Sun Mar 05 18:02:25 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 1 Sun Mar 05 18:02:25 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 1 Sun Mar 05 18:02:25 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 2 Sun Mar 05 18:02:35 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 1 Sun Mar 05 18:02:52 2017 209.251.223.129:0 73.0.209.0:0 [TCP- or UDP-based Port Scan] 1 Sun Mar 05 18:07:13 2017 [Ping Of Death] 2 Sun Mar 05 18:07:15 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 2 Sun Mar 05 18:07:18 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 1 Sun Mar 05 18:07:24 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 1 Sun Mar 05 18:07:27 2017 121.13.197.171:0 73.0.209.0:0 [Ping Of Death] 2 Sun Mar 05 18:07:28 2017 121.13.197.171:0 73.0.209.0:0 [Teardrop or derivative] 2 Sun Mar 05 18:07:30 2017 121.13.197.171:0 73.0.209.0:0 [Illegal Fragments] 1 Sun Mar 05 18:11:02 2017 121.13.197.171:0 73.0.209.0:0 [TCP- or UDP-based Port Scan] 1 Sun Mar 05 18:16:51 2017 [FAILURE: User interface login] 2 Sun Mar 05 18:16:56 2017 [SUCCESS: User interface login] 1 Sun Mar 05 18:17:00 2017
