Magister76
Jul 23, 2016Tutor
How to change the router's MAC address
Hello, I want to change the MAC address for my Netgear Nighthawk router. I do not see any option for this in the router's configuration menu. I know that this is possible with other Netgear rout...
TheEther
Jul 23, 2016Guru
The MAC address is so integral to cable Internet service that it doesn't really make sense for it to be changeable. You could effectively steal someone's service with that capability.
VE6CGX
Jul 23, 2016Master
Any piece of NIC , WiFi card or router has unique MAC address embedded in the unit when they were made. It is like your SSN, Do you think
there would be two identical SSN or two identical plate no. for two different cars? Another word it is like finger print. But... you can change it
getting into brain of the hardware by hacking. But I don't see the purpose. In the case of router you have two MAC one for wired, one for wireless. May I ask why you want to change it? Or I think you are talking about MAC cloning when you set u[p the router? If you play with MAC cloning
you can lose I'net connection.
- Magister76Jul 23, 2016TutorYes, I think I'm refering to MAC cloning. I guess some people also use the word "spoofing". The purpose is to get my ISP to issue me a new DHCP IP address.
- VE6CGXJul 23, 2016Master
What is the purpose of wamnting different address? What did you try so far?
- Magister76Jul 23, 2016TutorI have my reason and I don't really feel like it matters for this discussion. I know how DHCP works and the ISP leases an IP that is tied to the MAC address. If I call them they won't change the IP. That's their policy but technically they are easily capable of doing it. I've tried rebooting the router/modem but obviously the IP doesn't change because the MAC is the same and it picks up the same lease from the ISP. So is there a way to do what I want to do, short of buying a whole new router/modem?
