Magister76
Jul 23, 2016Tutor
How to change the router's MAC address
Hello, I want to change the MAC address for my Netgear Nighthawk router. I do not see any option for this in the router's configuration menu. I know that this is possible with other Netgear rout...
VE6CGX
Jul 23, 2016Master
What is the purpose of wamnting different address? What did you try so far?
Magister76
Jul 23, 2016Tutor
I have my reason and I don't really feel like it matters for this discussion. I know how DHCP works and the ISP leases an IP that is tied to the MAC address. If I call them they won't change the IP. That's their policy but technically they are easily capable of doing it. I've tried rebooting the router/modem but obviously the IP doesn't change because the MAC is the same and it picks up the same lease from the ISP. So is there a way to do what I want to do, short of buying a whole new router/modem?
- TheEtherJul 24, 2016Guru
The short answer is, there is no way to change the MAC address without buying a separate modem and router.
What you are failing to understand is that this goes beyond tying an IP address to a MAC address. When it comes to coax cable Internet service, the ISP ties your Internet subscription to your modem's MAC address. As in, "Magister76 is a paying customer with MAC address XYZ". If you were, somehow, able to change your modem's MAC address, your ISP would no longer recognize your modem as being associated with you. You would be perceived as either a non-customer (e.g. a guy moves into a house and hooks up a modem without subscribing for service) or as another customer with the same MAC address. Do you see the havoc that would ensue if customers chould change the MAC addresses on their modems?
You correctly point out that an IP address is tied to a MAC address for DHCP. It's not too hard to guess that you want to change your IP address because you are being DoS attacked or you are trying to hide your identity. Changing the MAC address is often useful to force a change in IP address. The problem is that a combination router/modem only has one Internet-facing MAC address. In this respect, a modem/router is just like a pure modem in that its MAC address cannot be changed for the reason I gave previously.
You can try shutting off your modem/router for at least one full day in the hopes that the ISP's DHCP server will flush its IP to MAC assignment. If that fails, then you will have to replace your modem/router. If you expect to change your IP address multiple times, then I suggest you buy a separate modem and router. This will decouple the customer-to-MAC and IP-to-MAC association (i.e. your modem's MAC identifies you as a customer and your router's MAC is used for IP adddress assignments). Then you can use the router's MAC spoofing/cloning feature to force IP address changes.
- Magister76Jul 24, 2016TutorTheEther, thanks for the explanation. I appreciate that. Just to verify what you are saying...I think I understand now that since my Nighthawk is an all-in-one cable modem and router device, there is only one WAN facing MAC address and that, therefore, the software hasn't been programmed to allow MAC cloning since it would be disruptive to the ISP. Also, I think I understand from what you said, if I had a cable modem and a router as two separate devices, the router would have it's own MAC and the cable modem would also have it's own MAC. And, therefore, the feature to allow MAC spoofing would be enabled for the router since doing so wouldn't interfere with the cable modem's MAC. Now I have another question (assuming what I said above is correct)...if I did go ahead and get a separate router and a separate cable modem, would cloning the MAC of the router work to get a new IP lease even though the MAC of the cable modem would stay the same? I'm not familiar with how DHCP operates with ISP's and their cable modems, but it seems to me that, regardless of the router's MAC address, if the MAC of the cable modem does not change then the leased IP would stay the same. Thoughts?
- VE6CGXJul 24, 2016Master
Only once I managed to do that. Complaining about my cable signal quality/speed non-stop to my ISP. Finally they did something, next thing I know I was given different address.
Checked 3rd party f/w on this?
Magister76 wrote:
TheEther, thanks for the explanation. I appreciate that. Just to verify what you are saying...I think I understand now that since my Nighthawk is an all-in-one cable modem and router device, there is only one WAN facing MAC address and that, therefore, the software hasn't been programmed to allow MAC cloning since it would be disruptive to the ISP. Also, I think I understand from what you said, if I had a cable modem and a router as two separate devices, the router would have it's own MAC and the cable modem would also have it's own MAC. And, therefore, the feature to allow MAC spoofing would be enabled for the router since doing so wouldn't interfere with the cable modem's MAC.Yes, this is correct.
A pure modem is a layer 2 networking device. It won't request an IP address from your ISP. Only your router will request an IP address, so MAC cloning will work.
VE6CGX wrote:
Checked 3rd party f/w on this?3rd party firmware is virtually non-existent for router/modems. You can probably count on one hand the number of models with 3rd party firmware. On this list, for example, I think the DGND3700 is the only one.
That makes perfect sense. Thanks again. Now I think I want to buy a separate router and cable modem. I really like the features of the Nighthawk. Would you recommend a router that is comparable to the Nighthawk? Especially one that has MAC cloning capability. And, as far as the cable modem goes, I guess any DOCSIS 3 would be fine?
TheEther wrote:A pure modem is a layer 2 networking device. It won't request an IP address from your ISP. Only your router will request an IP address, so MAC cloning will work.
